Author Topic: a few issues with my 8v, advice needed : )  (Read 4404 times)
Offline lints
Re: a few issues with my 8v, advice needed : )
« Reply #10 on: 16 August 2004, 22:07 »
cheers for the advise :)
i'll check that area for a crack tomorrow when it's light. all these little niggles are getting anoying now so im trying to get them all sorted out once and for all
Offline RICK.G.
  • Old git after info for my boys motah
« Reply #11 on: 17 August 2004, 21:24 »
Also check your pressure cap m8 the O ring was non existent on my lads one not uncommon I've been told, and your other proble sounds like a vacumn fault hads this on other makes
Offline bishthefish
« Reply #12 on: 17 August 2004, 22:30 »
yes, coolant caps cause a lot of grief and are always overlooked !!!
bishthefish@btinternet.com  VARIOUS NEW AND USED MK3 BITS USUALLY AVAILBLE
Offline piggy
  • What you lookin' at sonny?
« Reply #13 on: 18 August 2004, 00:49 »
With my G(ro)Ti 1988 8v I had the same problem with the coolant slowly going down. Changed a few things including the coolant cap, but found a small amount of water around the base of the cap ???
Eventually changed the water/anti freeze putting in the correct ratio as recommended by Haynes and it seems to have worked :D
Think it was to do with it boiling slightly and the extra anti freeze raised the boiling point. Too many water only top ups ;D
Offline Gambit
« Reply #14 on: 18 August 2004, 13:18 »
you will be able to see any water leaks as there will be a white residue where it leaks
also, get a replacment coolant cap from VAG - they are only ?7 and work better than the GSF item that id originally purchased to replace it
