Author Topic: ABF into 16v dizzy question - any other advice welcomed  (Read 967 times)
Offline topbloke77
Greetings.
I am fairly inexperienced at all of this so go easy if this question is silly.
I have the opportunity of buying a 2Ltr ABF. Just the complete block and head with no ancilleries. Does my dizzy from my early 89 16v KR fit?
I have read the sticky abf into 16v but there was no mention.
Any other comments and advice regarding this conversion are welcomed.
Thanks in advance
£500 Wondercar!  MkII 16V
Offline danny_p
Re: ABF into 16v dizzy question - any other advice welcomed
« Reply #1 on: 14 April 2009, 23:39 »
yes it fits. use kr dizzy if on k jet   abf one if on digifant 3
all the VW's have gone bar 1.
Offline topbloke77
« Reply #2 on: 15 April 2009, 09:33 »
Thanks for the reply.
Am I correct in saying that everything from my KR unit will bolt onto the ABF unit without any issues. (Doubt that with my mechanics skills!)
What should I be buying in terms of Gasket sets for this job?
« Reply #3 on: 15 April 2009, 10:00 »
yep!
gasket sets most of it will be the same between abf and kr, mostly if given the choice you want abf bits but things like upper inlet manifold gasket must be KR.  timing belt bits ABF, also water/pas pump belts depend on what anxilery setup you use, if included use the ABF stuff.
oh and you'll want KR plastic front and thermostat housing flanges, might as well bung a new stat and seal on while you're down there
« Last Edit: 15 April 2009, 10:02 by rubjonny »
