Author Topic: Rear Compensator leads to... ?  (Read 1821 times)
Offline juleshs
Re: Rear Compensator leads to... ?
« Reply #10 on: 15 April 2009, 12:07 »
the front are 239mm,the rear are shoes and master cylinder is origanal 1300. if i get the specific non brake regulator rear cylinders is that going to be ok as i really dont want to chop my spanking new brake lines unless i have to
« Reply #11 on: 15 April 2009, 12:58 »
also may be worth checking both sides are the same wheel cylinder, gsf have managed to supply me with 2 completly different ones in the past
as long as they're non-bias valve equipped wheel cylinders what you have is just fine
Offline Diamond Hell
  • Opinions я Us
« Reply #12 on: 15 April 2009, 13:08 »
With the correct-spec slave cylinders you should be fine - that's how the braking system was designed out of the box and you haven't changed the spec on it.
Offline juleshs
« Reply #13 on: 15 April 2009, 13:42 »
thanks for all the info, im sure it wont be long before im back needing more
