Author Topic: Brake help/opinions...  (Read 1555 times)
Offline twistedblack69
  • Proud mk2 user and abuser
« on: 14 April 2009, 20:59 »
Hey all, thinking of changing the brakes on my 8v for some drilled and grooved discs. Only thing is, IMO, the current ones are a bit small. I have 5 spoke alloys on, which show off a lot of the discs, but I think there's quite considerable space between the inside of the alloy and the edge of the disc, like so:
I think it could do with bigger discs, 256mm maybe, from the 16v, or even 280mm from the G60's, but how much will getting the neccessary parts for each be?? And am I right in thinking that 280mm and 256mm can both be fitted to the same hubs and carriers?? Will I need to change the master cylinder from the 8v one also??
Obviously getting drilled and groove 239mm discs would be the cheaper and easier option, but for the people that have done the conversion, would it be worth the effort?? (I am also planning an engine conversion, but not for a couple years, when I'm out of uni). And can anyone point me in the direction of some decent 239mm discs, as I can't find any :(
If you can make sense of that, I commend you....
Offline drapergti
Re: Brake help/opinions...
« Reply #1 on: 14 April 2009, 21:05 »
I have been looking at this alot see a couple of posts below (Audi A3 Brakes)
Heres one of the results I found from this forum which may be of use.
http://www.golfgtiforum.co.uk/index.php?topic=63138.0
Offline gavL
« Reply #2 on: 14 April 2009, 21:09 »
If I remember correctly there is an excellent guide on this forum on how to do the conversion, I will take a look when I get in from work and see if I can dig it up for you :)
G60 Hubs & Carriers ain't cheap as well...
| DubNorthEast |
Offline drapergti
« Reply #3 on: 14 April 2009, 21:17 »
Offline gavL
« Reply #4 on: 14 April 2009, 21:19 »
It may be this one?
http://www.golfgtiforum.co.uk/index.php?topic=106287.0
The exact one. Saved me a job for after work ;) Cheers!
| DubNorthEast |
Offline drapergti
« Reply #5 on: 14 April 2009, 21:20 »
No worries  :smiley:
Offline jacko16v
« Reply #6 on: 14 April 2009, 21:25 »
Got a full 16v setup for sale if you need any bits?
All new discs, pads, hoses and wheel bearings in the hubs
Offline k4ith
« Reply #7 on: 14 April 2009, 21:32 »
hubs you say :wink: how much? 4stud?
MKV Golf GTI Edition30, GIAC Pump&Race Map, AutoTech Fuel Pump, R32 Front Brakes, Dbilas Flo-master Intake, S3 Intercooler.ECS Dog Bone Insert.
MKII GTI 8v Tornado Red 88 - Das Projekt
Offline Conker
« Reply #8 on: 14 April 2009, 21:32 »
Just my opinion, but I wouldn't fit grooved discs again due to increased noise under heavy braking.
« Reply #9 on: 14 April 2009, 21:45 »
How much you looking for Jacko??
