Author Topic: 16v loss of power / weird engine noise when hot  (Read 1650 times)
Offline Skiing
« on: 13 April 2009, 21:30 »
Hi all,
On my way back into London this evening and car started to hesitate on hard throttle - got worse and worse (having to have a lighter and lighter right foot) and the engine was sounding funny - sort of flat exhaust note - power got worse and worse....
I stopped and let her cool for about 20 minutes (oil temp from 104 down to 90) and water temp down towards half way and she was much better - but started to play up again (started to hesitate etc) on te way home...
I dont think it is a fuel thing as she was fine on low fuel all weekend when blasting around - it seems to be only after a long journey and when she is hottest...
Any ideas? am going to try temp sensors / check all vacuum pipes etc.. but anything else?
1988 Golf GTi Mk2 16v 2.0 9a bottom end- Oak Green - 3 door - full black factory leather...
Offline Diamond Hell
  • Opinions я Us
Re: 16v loss of power / weird engine noise when hot
« Reply #1 on: 13 April 2009, 23:19 »
Did you replace the fuel filter/lift pump like you were talking about in the other thread?
Offline Skiing
« Reply #2 on: 14 April 2009, 09:36 »
I did the lift pump but not the filter... this might be my problem - but surely if it was a fuelling issue it would happen whenever I was low on fuel, but on the weekend the car was running really well right into the red on the fuel gauge....
Also, I had the same symptoms - hesitancy, misfiring / popping / no power on the way out of London - I stopped for about ten minutes and tightened the fuel hose clips going into the intank pump and also just generally tightened any jubilee clips / checked hoses  in the engine bay (NB got a small electric shock from the end of the dizzie) and that sorted it out - great power and acceleration all the way home.
So am not sure what it is...
Offline jezza16v
« Reply #3 on: 14 April 2009, 09:58 »
Your 'shock' from the dizzy may be a clue. If you've got voltage leaking from there then this will give a weaker spark at the plugs, you may have a hairline crack in the cap or a lead breaking down. You need a good strong spark when running at wide throttle & higher rpm. If your fuel filter is clogged it will restrict the fuel flow you need at higher revs regardless of how full the tank is.
Offline Skiing
« Reply #4 on: 14 April 2009, 13:25 »
Thanks all, I will spend the weekend checking every connection, replacing the fuel filter etc... but any other ideas?
« Reply #5 on: 14 April 2009, 14:00 »
as said shouldnt have got a shock, get all the ign bits replaced before you mess about any further
Offline Skiing
« Reply #6 on: 14 April 2009, 14:42 »
will check electrical bits, but has had new VAG leads, sparks, dizzie cap recently... but will check earths etc and all connections...
Offline Ben Lessani
« Reply #7 on: 14 April 2009, 17:50 »
 :rolleyes:
Offline Conker
« Reply #8 on: 14 April 2009, 21:39 »
Just a quickie... Don't ignore new items when fault testing. I bought brand new leads that turned out to be faulty, which led to two months of frustrating problem solving, all because I assumed the leads were fine.
