Author Topic: ecu change  (Read 2041 times)
Offline RTechUK
  • R-TECH OFFICE 01455 617233
Re: ecu change
« Reply #10 on: 12 April 2009, 22:23 »
You cannot plug and play with the 180bhp ecu. It would be a huge task to get it working on the 150bhp AGU engine.
AGU ecus are M3.8 using simple mapping, ingnition, fueling and boost solinoid control
AUQ ecus are ME7.5 which use a complex torque based system,  compare to the m3.8 ecu the me7.5 uses more sensors inc a map sensor, plus the loom and ecu conectors are totally different, the me7.5 controls the power via an electronic throttle control where the agu uses a cable control.
The AGU me3.8 is more tuneable  compared to the me7.5 ecu plus it will return great results once remapped.  :wink:
 01455 617233
