Author Topic: Revs moving when idle??  (Read 3398 times)
Offline 1.6mk4GOLF16v
« on: 12 April 2009, 13:41 »
This morning just as i got to work i noticed that after i had parked the rev counter wasnt still as it should be
Every second or so it would drop 1000rpm so it drove it round the block, parked up n its still doing it
Opened the bonnet and the engine seems to give a bit of a shake aswell, dont sound to healthy neither!
:sad:
What could it be?
1.6 16v AZD
RS8s 225/35/19
Full powerflow decat exhaust
Blanked EGR
Pipercross panel filter
watch this space for the rest...
Offline Adam
Re: Revs moving when idle??
« Reply #1 on: 12 April 2009, 15:26 »
Mine does that when I have the Air con on.
That engine is giving you a lot of trouble. Time to change?
:lipsrsealed: http://www.golfgtiforum.co.uk/index.php?topic=58241.0 :lipsrsealed:
Down Hill From Here.
« Reply #2 on: 13 April 2009, 08:56 »
was it really 1000rpm, or 100rpm?
« Reply #3 on: 14 April 2009, 13:54 »
 :grin: u know what i mean, still does it on the odd occasion, could the coil packs be faulty?
also im suspecting that the cars sometimes running on 3 cylinders as it gets really sluggish after driving for approx 30 mins
gonna plug in VAGCOM tomorrow morning to check for fault codes, aahh another question can VAG be used while the engine is running?
gotta change the spark plugs tomorrow aswell
1.6 16v AZD
RS8s 225/35/19
Blanked EGR
« Reply #4 on: 14 April 2009, 15:11 »
good idea and yes it can :)
« Reply #5 on: 14 April 2009, 17:18 »
so whats the difference of using VAG while engines on or off?
1.6 16v AZD
RS8s 225/35/19
Blanked EGR
« Reply #6 on: 14 April 2009, 17:26 »
well you can read fault codes etc with the ignition on regardless of if engine running, only difference is with engine running is you'll see parameters like engine rpm etc actually read something
« Reply #7 on: 14 April 2009, 18:56 »
aahh ok, ill give it a go and let you know the outcome  :smiley:
1.6 16v AZD
RS8s 225/35/19
Blanked EGR
