Author Topic: What kills a maf?  (Read 5741 times)
Offline Dubbz
Re: What kills a maf?
« Reply #20 on: 11 April 2009, 22:43 »
Have a smell of a maf, mine smelt sooty.  :sick:
2002 TDI se 100bhp-ish Auto/tip Black Magic. :cool:
Offline jonnyturbo
« Reply #21 on: 11 April 2009, 22:45 »
lmao dubbz will put it on my jobs to do list LMAO
Offline topher
  • Administrator
  • fully functioning
« Reply #22 on: 11 April 2009, 22:46 »
Care to explain how std cars,still need replacement mafs?
Gremlins, magical fairies, or parts not fit for purpose in the first place.
Offline Dubbz
« Reply #23 on: 11 April 2009, 22:47 »
:afro:  :grin:
roll a twenty up while ya in there.  :evil:
Offline Grand Master Patch
« Reply #24 on: 11 April 2009, 22:48 »
The solution?
Oil catch can,read up about it :laugh:
Offline Dubbz
« Reply #25 on: 11 April 2009, 22:52 »
The solution?
Is that the same as a breather pipe going back in to the sump?  :undecided:
« Reply #26 on: 11 April 2009, 23:10 »
The solution?
Not even close....
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #27 on: 12 April 2009, 10:59 »
I think it's just the fact it's super heated on shut down everytime, metal can't cope with that constantly so gives up. Also if it has some crap on it when it does this it could react and burn the sensor more
I've had a K&N on mine for over a year now and I've never had to replace the MAF so I don't believe the hype about them
Offline RTechUK
  • R-TECH OFFICE 01455 617233
« Reply #28 on: 12 April 2009, 12:30 »
IMO its not 100% going to be down to the engine oil vapor,  I cannot see how oil can get blown back on to the maf element? Look at a 1.8t DBW MAF and you will see what I mean.  Plus when you lift off from under load the air is pulled towards the turbo , because the turbo is still spooling and pulling air in at a lowe volume. If  the DV is fecked the turbo would stall and the air would come come back toward the MAF.
 If the vapour was comming back in to the maf the maf would be wet with oil like the inside of a IC pipe?  It is down to ware and tear, constant heating and cooling of the elements, vibration, water vapour, dust, air flow errosion.
Cheap cone filters kill MAFs at a quicker rate due to added, vibrations, extra heat and larger dust particals being allowed it. Plus Oiled filters do cause issues, look inside a MAF from a car running a oiled filter and it will look like it have a sticky texture and dust all over the internal surface.
Plus MAF are degined not to last forever if you know what I mean. :wink:
On a car with poor crank/cam case breathing the oil vaspour can reduce the the power by a very small amount, fitting a catch tank can over come this. My calibra turbo had to have a catch tank fitted to stop it smoking due to the poor oem breather set up,When I went around a right left hand bend my induction took a nice gulp of oil which caused a flat spot..   The OEM breather set up on the 1.8t aint too bad so you should not see a gain in performance by fitting a catch tank.
Nick
 01455 617233
« Reply #29 on: 12 April 2009, 13:03 »
When a carbonio cai,or any after market cai is fitted to a 1.8t,am i right in saying the sound of the dv is louder due to it echoing inside the pipe?
