Author Topic: newbie needs help please!  (Read 7308 times)
Offline mart08uk
Re: newbie needs help please!
« Reply #20 on: 11 April 2009, 22:51 »
 :smiley: well i did this to mine after bad idle, mines a 1.6 btw, but the tb's were clean-ish but the breather pipes needed cleaning, did that put back and idle was perfect  :smiley:
Offline northeast_gti-t
  • "1.8T AGU"
« Reply #21 on: 12 April 2009, 00:59 »
lol u getting like rich and rhyso matt with ur links lmao
Part of the link team  :grin: :grin: :grin:
yep :afro:  :grin: i am now
2000 Mkiv GTi 1.8T AGU
Offline mikemk4gti
« Reply #22 on: 12 April 2009, 11:39 »
 Ok, so checked with vag com this morning, turns out that if i run it as an administrator it works fine.
so, i had 3 fault codes stored:
17705 PRESSURE DROP BETWEEN TURBO AND THROTTLE VALVE (CHECK DV!) P1297 - 35-10
17545 P1137 - 35-10  shareware so no description
16514  P0130 - 35-00  shareware so no description
i've cleared the codes and so far this morning it is driving perfectly, I've heard about dv problems before with other cars - could this be the problem?
51 mk4 gti 1.8t AUM | 05 Audi A3 3.2 Quattro S-Line | 01 A3 1.8t Sport | 02 Golf 25th Anni 1.8T | 03 mk4 GTI AUQ | 05 Leon Fr TDI 150 | mk2 golf gti 8v | 01 Audi S3
Back in my old MK4 '01 AUM!
http://uk-mkivs.net/forums/t/400214.aspx
VagCom, VagTacho, MTE, Needles, Key coding, Locked beeps etc availab
Offline Steve_PD
« Reply #23 on: 12 April 2009, 11:58 »
  17545/P1137/004407 - Fuel Trim: Bank 1 (Add): System too Rich
Possible Symptoms
    * Malfunction Indicator Light (MIL) active
Possible Causes
    * Mass Air Flow (MAF) Sensor faulty
    * Fuel Pressure Regulator faulty
    * Fuel Injector(s) faulty
    * Oxygen Sensor Control faulty
          o Oxygen Sensor(s) faulty
    * Evaporative Emission (EVAP) System faulty
Possible Solutions
    * Check Mass Air Flow (MAF) Sensor
    * Check Fuel Pressure Regulator
    * Check Fuel Injector(s)
    * Check Oxygen Sensor Control
          o Check Oxygen Sensor(s)
    * Check Evaporative Emission (EVAP) System
  16514/P0130/000304 - Oxygen (Lambda) Sensor B1 S1: Malfunction in Circuit
Possible Causes
    * Oxygen (Lambda) Sensor Heating Bank 1 Sensor 1 faulty
Possible Solutions
    * Check Oxygen (Lambda) Sensor Heating Bank 1 Sensor 1
♦Theres your other codes  :smiley:
Offline richw911
« Reply #24 on: 12 April 2009, 12:24 »
Boost leak will be a pain to find  :sad:
Offline 1.6mk4GOLF16v
« Reply #25 on: 12 April 2009, 14:46 »
hi, breather pipes??
1.6 16v AZD
RS8s 225/35/19
Full powerflow decat exhaust
Blanked EGR
Pipercross panel filter
watch this space for the rest...
Offline jonnyturbo
« Reply #26 on: 12 April 2009, 15:41 »
yup boost leaks are a pain
Offline mikemk4gti
« Reply #27 on: 12 April 2009, 16:13 »
thanks steve_pd for that.
Well, done about 15 miles today including slow driving and the car has been faultless. i did take the dv off the inlet pipe this morning to see is it was leaking at idle but seemed ok.
Offline richw911
« Reply #28 on: 12 April 2009, 16:42 »
Boost leaks do that tho fine one day not the next - keep an eye on it  :smiley:
Offline jonnyturbo
« Reply #29 on: 12 April 2009, 17:06 »
if it gets too bad there is always a smoke test throught your pipes
