Golf mk2
Replacing Wheel Hub on Front Tyre?
4
Topic: Replacing Wheel Hub on Front Tyre? (Read 6694 times)
Ben Lessani
The poor mans MK2 Haynes author
Re: Replacing Wheel Hub on Front Tyre?
Reply #30 on:
12 April 2009, 21:02 »
http://www.golfgtiforum.co.uk/index.php?topic=49436.msg869371#msg869371
Balljoint bottom
Strut top
Track rod left
Driveshaft bottom right
It should all be obvious. But, if you can't tell a track rod end from a driveshaft - I'm not sure you should be disassembling a major component of your car without help from someone who knows what they are doing.
Here's how your hub should look after a fresh bearing
Last Edit: 12 April 2009, 21:14 by Ben Lessani
AudiA8Quattro
Forum addict
Reply #31 on:
12 April 2009, 21:05 »
Or someone with a big hammer?
4
Golf mk2
