Author Topic: best suspention set up for mk2 16v?  (Read 1998 times)
Offline julie
« on: 11 April 2009, 15:12 »
hi im looking to change my suspention set up just wondered if anyone can recommend some good shocks and springs? and how much do you suggest lowering it by?
the car already has coilovers on it,cant remember the make think they came from venom but find them a bumpy drive but does handle very well.
VeeDubGTI16v
Re: best suspention set up for mk2 16v?
« Reply #1 on: 11 April 2009, 18:48 »
the best for the road imo is the koni top adjustables/eibach springs. handles well and isnt too bad over bumps (feels like oem compared to those cheap coilovers). they arent cheap though.
« Last Edit: 11 April 2009, 19:11 by veedubgti16v »
Offline julie
« Reply #2 on: 11 April 2009, 20:00 »
yeah have heard koni are good! think coilovers are supersport ones!
Offline OakeyDoak16v
« Reply #3 on: 12 April 2009, 00:35 »
Weitec Ultra GT kit. £345 very very good value for money. :cool:
Offline gstar-dubworld
  • Here comes the piano man - his a peaceful man..
« Reply #4 on: 12 April 2009, 02:14 »
+1
Just for reference really..
My car runs the GT kit, remember Weitec is the smaller brother to KW so no compramise in quality & good value for your money, after trying many different set-ups this kit worked well for what I was looking for in the handling characteristics, it's also height adjustable on the rear and it's a shorter damper/rod to match the shorter springs.
Mine is the 40/40 kit, with front Bonrath top mounts, Eibach ARB's with 16v drop links, standard rear axle & front w/b bushes.
Front ride hieght set to 40/41mm, camber 1 degree negative & rear ride set to 37mm
Nose down stance has the following values
1.) Car looks right to the eye
2.) Better stability under braking
3.) Under full throttle the nose remains planted and the rear compression is down to a minimum under load
Offline paultownsend
« Reply #5 on: 12 April 2009, 11:04 »
weitec kit for me too. dont be tempted to go too low. -40mm  is best. and thats rated from carb model. get them wishbones flat!
Offline MarkS
« Reply #6 on: 12 April 2009, 17:12 »
Weitec seem a good option!
I've got Koni adjustables and Eibach springs.
Really sharpens up the handling  :cool:
Offline julie
« Reply #7 on: 12 April 2009, 18:45 »
ok so looks like either the weitec gt kit or the koni adjustables and eibach springs both simaler priced! what is the ride like on these? and handeling?
not sure what ones to go for!
« Reply #8 on: 12 April 2009, 18:54 »
Both very good, the Koni/Eibach set-up has the additional ability to adjust the damping, the Weitec is an all in one setup spings/dampers by one company with shorter shocks/rods to match the springs, you have 4 position at the back of the Weitec which can be dialed to get that nose of the MK2 pointing down but no damping adjustibility.
Offline julie
« Reply #9 on: 12 April 2009, 22:43 »
how bumpy is the ride with these suspention set ups?
