Author Topic: Mk2 GTI 8v - Overheating when idle  (Read 5325 times)
Re: Mk2 GTI 8v - Overheating when idle
« Reply #10 on: 13 April 2009, 13:08 »
what does the oil temp say?
Offline Sykopaf
« Reply #11 on: 13 April 2009, 13:17 »
That's another problem needs sorting. The computer isn't working, so I can't see the oil temp  :undecided:
Let them see your black heart, baby!
« Reply #12 on: 14 April 2009, 10:07 »
ah, its nice to get a 'second oppinion' when you're diagnosing coolant faults  :sad:
Offline Sykopaf
« Reply #13 on: 14 April 2009, 15:53 »
A new temp sender is only like £5.50 and I can fit that myself (being a complete simpleton and relying entirely on my Haynes manual!), but I wouldn't know where to start on the computer!
Cheers for the help
Offline Sykopaf
« Reply #14 on: 18 April 2009, 10:00 »
A little help?  :huh:
I'm trying to replace the temp sender, only when I take the part out as instructed in the Haynes manual, it doesn't appear to be what it's supposed to be.
I've removed both plugs as below, it's supposed to be the front of the two:
These are the plugs I've removed:
And this is the new temp sender:
I feel like a kid where you've got to put the shaped bricks in the correct holes. The cube won't go in the round hole! :undecided:
I'm a complete novice as you can tell so if someone could point out my stupidity and give me a nudge in the right direction?
« Reply #15 on: 18 April 2009, 10:17 »
that is an early 8v and 16v sensor, so no good to you :(
blue one is for the ECU and you want from VAG:
025 906 041 A - 13.33+VAT
black one a gsf or scrappy one would be ok as the gauge isnt so important to be spot on, but if you want a vag one its:
251 919 501 D - 19.95+VAT
Offline Sykopaf
« Reply #16 on: 18 April 2009, 11:16 »
Legend, cheers jonny.
Was scratching my head cos the sender I bought matches the one in the Haynes manual for 1.8 fuel injected. Hadn't occurred to me there'd be a different one on mine.  :embarassed:
Offline Khare
  • The bear that khares
« Reply #17 on: 18 April 2009, 12:44 »
judging by the colour of the water id flush the system, unless that is the colour of the coolant...
Offline Sykopaf
« Reply #18 on: 18 April 2009, 16:42 »
It's Halfords brand 'colour of piss after ten pints and a curry' coolant  :wink:
Offline Sykopaf
« Reply #19 on: 25 April 2009, 15:50 »
 :sad: I've put the new temp sender in, still overheating. It's boiling over way before it should. Any other ideas?
