Author Topic: rear callipers  (Read 2151 times)
Offline beechymonza
  • mad beech
rear callipers
« on: 10 April 2009, 09:48 »
hi, im changin rear brake pads on my 16v, when windin the calliper back in, do i wind them clockwise or are they anti clock wise, they dont seem 2 be movin anywhere, :cry: :cry:
No guts No glory,
Offline Ben Lessani
Re: rear callipers
« Reply #1 on: 10 April 2009, 11:06 »
Looking at your caliper winders, you should have two. One with a left hand thread, one with a right hand thread.
Most are marked R and L so you can identify which side of the car to use them on.
IIRC the right hand thread is used on the right side, but I wasn't aware the Golf calipers were sided.
Pop the cap of the fluid reservoir and pump the brake a couple of times, it should free up the piston.
Re: rear callipers
« Reply #2 on: 10 April 2009, 11:31 »
erm no, both are the same thread. clockwise to wind in, anti-clockwise to wind out
what you need is a proper wind back tool, need it to put pressure on the piston while you wind it:
http://www.justoffbase.co.uk/s.nl/category.113/it.A/id.7397/.f
« Last Edit: 10 April 2009, 11:35 by rubjonny »
Offline topbloke77
Re: rear callipers
« Reply #3 on: 11 April 2009, 15:52 »
As RubJonny just said.....you'll need a proper caliper wind in tool. You can sometimes get away using circlip pliers but it is 1000 times easier with the correct tool. You can end up turning the piston for about half an hour before you realise its not going in! I did this once! Ended up getting a borrow of the correct tool abd it took about 30 seconds.
£500 Wondercar!  MkII 16V
Offline Steve_B
Re: rear callipers
« Reply #4 on: 11 April 2009, 17:52 »
Also, seemed to make it easier for me to clamp open the rear bias valve  :smiley:
Offline whiter_than_white
  • Seize the day or die regretting the time you lost!
Re: rear callipers
« Reply #5 on: 11 April 2009, 21:34 »
it's also sometimes easier to clamp the flexi hose (assuming you've not changed them for braided) and crack off the bleed nipple before pushing the piston back. but make sure to catch the fluid, can get very messy otherwise
Offline skem55
Re: rear callipers
« Reply #6 on: 12 April 2009, 01:37 »
hmm bit like mine been trying to unseize mine even with the wind back tool they were stiff as! the compensator valve seems stuck on my 16v too, mite have to change the lot!!
stuart
Offline beechymonza
  • mad beech
Re: rear callipers
« Reply #7 on: 12 April 2009, 10:14 »
stuart
think im gonn a change the lot, handbrake bit wont move either, took it 4 m.o.t yesterday, explained this 2 the guy doin it and he passed it, he likes my car an knows i gonna get it done, fair play 2 him :grin: :grin:
No guts No glory,
Offline Ben Lessani
Re: rear callipers
« Reply #8 on: 12 April 2009, 10:16 »
Motherf**ker
Offline beechymonza
  • mad beech
Re: rear callipers
« Reply #9 on: 12 April 2009, 10:23 »
Motherf**ker
yeah baby
No guts No glory,
