Golf mk3
hardmonkeys
What should the idle speed be?
Topic: What should the idle speed be? (Read 1297 times)
krhall
09 April 2009, 21:16 »
What should the idle speed be on my 1.8 cabrio? I reckon it is far too low at 750 and needs to be nearer 1000 rpm?
Also if it is too low how do I go about adjusting it, what tools? where? and how?
Cheers,
Kev
jay cee
GTI forum regular
always in front
Re: What should the idle speed be?
09 April 2009, 21:47 »
mine is running at 798
1997 Golf GTI 8v - Dragon Green
http://www.nwdubs.com
www.rouleur.cc
slicksps
Web Design and now DIY mechanic for mkIII CL
10 April 2009, 02:38 »
Mines a non-cab but a 1.8 mk3 and idles about the same. Just above rattly... works for me
boneybradley
Forum Supporter
Serious forum addict
Back in a Mk3...
10 April 2009, 11:08 »
vacum leaks are common on the 1.8 and this lowers the idle speed (and can make it slightly lumpy!)
adamrob69
Guest
10 April 2009, 13:51 »
i would say 750 is not far off. Its an automatic idle, you cannot adjust or change it. Your idle point depends on all the various sensors, so if it sounds a bit rough or not quite right then start looking into it starting where bradley says.
Golf mk3
hardmonkeys
