Author Topic: Clutch master and slave cylinders  (Read 2875 times)
Offline DarnPB
  • Formerly Darnpistonbroke
« on: 09 April 2009, 17:31 »
I went to GSF today and asked about the above for my G60 and they do not recognise the set up. I came away with MKIII 16v items in the hope that they will fit. Now I have not matched these up with what is on the car yet, so can anyone tell me if I have the correct items? And if I don't, what the correct items are? Its for a 1991 Golf G60 with a cable change gearbox and hydraulic clutch! (Obviously) :wink:
Offline danny_p
Re: Clutch master and slave cylinders
« Reply #1 on: 09 April 2009, 23:55 »
the slave will defantly fit
all the VW's have gone bar 1.
Offline DarnPB
« Reply #2 on: 10 April 2009, 19:38 »
I hope the master does too as it cost me half of my left arm. And that was for a copy! :sad:
« Reply #3 on: 10 April 2009, 20:31 »
I think you will find the master is the same as well I believe.
Offline Diamond Hell
  • Opinions я Us
« Reply #4 on: 10 April 2009, 21:00 »
Golf3 LHD: 1H1721401
Golf2 LHD: 357721401
Should have gone for the second one, which is fitted to the 88-93 Passat and is the same one as yours.
Offline DarnPB
« Reply #5 on: 10 April 2009, 22:50 »
Cool. I'll check out the part numbers when I get back. Thanks for that. Is the same also fitted to the Corrado G60 as I believe that is the one I have?
« Reply #6 on: 11 April 2009, 07:53 »
357 721 401 is fitted to the corrado up to chassis code 50-R-000 786, after that it got 3A1 721 388. same story on the passat as well, afaik the early/late cylinders cant be swapped either
Offline DarnPB
« Reply #7 on: 13 April 2009, 11:41 »
God knows what master cylinder I have here. The GSF No. is 71676. The P/No. is 1H2-721-401. And the P/No. on the box is a Bosch P/No. which is 0 986 486 045 (-001? :undecided:)
I'll have to confer with GSF armed with the P/No.s that were given here and see if they can cross refer them.
« Reply #8 on: 13 April 2009, 13:10 »
thats a RHD part number, the clue is the 1h2 bit ;)
tis a MK3 Golf part, listed for 92-98 Golf/Vento/Cab
Offline DarnPB
« Reply #9 on: 13 April 2009, 17:29 »
Bugger!
