Author Topic: something is wrong with my golf  (Read 4532 times)
Offline bully85
Re: something is wrong with my golf
« Reply #10 on: 08 April 2009, 23:14 »
mine was the same exactly the same water pump!!
Offline the_stink
  • A3 140 TDI
« Reply #11 on: 08 April 2009, 23:20 »
why is everyone  :cry: about a water pump?not much of a job really? :huh:
not really much of a job im having it change along with the cambelt on sat, got a water pump with metal fins :) but it was more the case that if it was the water pump and the negine overheats then you up the duff if your not carefull :tongue:
Offline Devilz
  • Cruisin is not a crime
« Reply #12 on: 09 April 2009, 00:05 »
yeah i thought it will be good idea to change timing belt as well while doing water pump as it will be easy to do then. Hope it will solve the problem
Offline Miggie
  • Golf I II III IV and perhaps V soon
« Reply #13 on: 09 April 2009, 01:01 »
Same thing happpened to me on my old 5dr and next day the waterpump had to be changed!
R-tech Agu k03s power!!
Offline Miggie
« Reply #14 on: 09 April 2009, 01:05 »
Another way to check is by feeling the top hose and also your heating inside the car wouldn't be working........
Offline Devilz
« Reply #15 on: 09 April 2009, 13:53 »
its sorted now  :smiley:
it was water pump causing problem. Replaced it and changed belt as well
Offline spetzdude
  • I Bleed Blue!
« Reply #16 on: 09 April 2009, 19:56 »
glad to here that!
how much did you have to pay if you dont mind me asking?
Performance mods: Revo stage 2 map, 5 Peice Hose Kit, TIP, evoloution motorsport air filter, N249 by-pass, Forge spliter valve, lowerd 50mm (KW), Front & Rear Eiabach ARB, Full Milltek Turbo back exhaust.
Cosmetic mods: Tints,De-wiperd the rear, De-badged front grill, Sharan rear badge, Rear spoiler, 4mo rear valance, 4mo front spliter, arero wipers, stubby areial, DOTZ 18" Alloys, Boost guage, Smoothed Bumbers, ECS N75 Vlalve.
BHP: 231
TRQ: 341.3
Offline jepc86
« Reply #17 on: 09 April 2009, 23:36 »
I get that warning every other day and the coolant is fine! Hope it isnt nothing major!
Offline richw911
« Reply #18 on: 10 April 2009, 09:29 »
If yours is not over heating you need a new coolant bottle as the sensor fails.
Costs around 10 pounds  :wink:
Offline JamieGTi
« Reply #19 on: 10 April 2009, 09:45 »
Mine had same problem. Turned out to be water pump aswell.
Sickner with mine was it was 3 hours after I bought the car and got it home  :sick:
