Author Topic: Chrome Internal Door Handles  (Read 8862 times)
Offline jontom
Re:Chrome Internal Door Handles
« Reply #10 on: 16 July 2003, 14:03 »
i just got mine from VGA parts, very good quaity chrome, nice and heavy too, well worth a tenner, vat, P+P. All i have to do now is fit em.
Offline Pimpster
« Reply #11 on: 16 July 2003, 14:33 »
When you've fit em please let us know how you did it and if so how hard or easy it was. that would be really helpful.
Offline jontom
« Reply #12 on: 16 July 2003, 17:08 »
hey Pimpster
      They were real easy to fit. Once the door panel was off it was a 1 min job, did both doors in 10 mins not bad after flicking through the haynes manual to see how the panel came off.  ;D A big improvement over the old tatty plastic ones.
Offline Pimpster
« Reply #13 on: 16 July 2003, 18:05 »
Thats great, cheers mate. glad to know it easy.
Offline seyles
« Reply #14 on: 30 July 2003, 15:38 »
Bought the handles from VAG Parts, very well made (VAG original), well worth the ?10. Fitted them without taking door cards off. Just prise off the door pull covers and use pliers to remove door handle bars, pull handle all the way open, slide out, slide new handle in, re-attach door handle bars with pliers (a bit tricky but possible). Replace covers and you?re done.
I also got Audi TT brake and clutch pedal rubbers from VAG Parts, Look great and direct replacement for golf rubbers. Accelerator pedal cover fits with a lot of persuasion!
Offline adyh
« Reply #15 on: 30 July 2003, 17:24 »
Have you got the VAG part number  ?
Offline adyh
« Reply #16 on: 30 July 2003, 17:34 »
sorry forgot about the start
they also have the rear door ones as well for 10.00
Offline seyles
« Reply #17 on: 31 July 2003, 09:18 »
adyh,
just go to http://www.vagparts.com/
click on 'shop now online!', put pedals in the quick search box it will bring up 3 different types, audi tt, 337 and R32. TT pedals are the cheapest though, ?5.14 for the clutch and brake rubbers and ?6.90 for the acc. rubber. You need to get the clutch and brake seperatly as they do fit differntly. R32 set is ?39.96 and 337 set is ?28.27.
Great mod, easy and much better than bolt on pedal extensions, rubber comes through the metal so your feet won't slip and the MOT man won't frown.
Offline adyh
« Reply #18 on: 31 July 2003, 09:56 »
Cheers ,
thats my dor handles ordered .... it should be fun fitting them  ???
