Author Topic: Eibach ARB Kit 25mm / 25mm  (Read 2893 times)
Offline 1688bran
Re: Eibach ARB Kit 25mm / 25mm
« Reply #20 on: 07 April 2009, 12:49 »
well u dont really need the rack .. TT is a short rack (lock to lock) if u on a budget u change the parts it need to be changed .(TT wishbones, TT or r32 front  anti roll bar ,TT drop link , TT hub carriers and TT/r32/lcr/s3 strut or collies ....
Offline the_stink
  • A3 140 TDI
« Reply #21 on: 07 April 2009, 12:51 »
ahh ok so mainly upgrading the wishbones for TT ones
Offline 1688bran
« Reply #22 on: 07 April 2009, 12:56 »
yeah ... TT wishbones is cast and the mk4 wishbone is pressed so during high speed cornering the mk4 wishbone bend slightly whereas the TT WISHBONE will stay the same ..... also TT anti roll goes under the driveshaft so when u lower the car it wont catch the driveshaft whereas the mk4 anti roll bar is on top of the driveshaft so when u go lower than 50mm it will stasrts to rub ...
Offline Steve_PD
« Reply #23 on: 07 April 2009, 16:57 »
from reading other posts is 28mm the best rear to go for?
depends on your style really - apparently the whiteline on its stiffest setting is equivalent to a 28mm bar (not 100% sure on this) but i've yet to try it out on that setting due to the crap weather
Pussy  :grin: :wink:
