Author Topic: mk3 golf tdi broken plastic in sump  (Read 5171 times)
Offline *tell*
« on: 06 April 2009, 20:58 »
i was driving along doing 70 mph
and oil buzzer came on ...
took the sump off and the oil pump baffle has broken into
alot off pieces.
i have fitted a new pump but not a baffle do i really need this  :undecided:
its number 24 thanks tell
Offline Len
Re: mk3 golf tdi broken plastic in sump
« Reply #1 on: 07 April 2009, 08:39 »
Strange!
So you have no idea why that broke? no big lumps of metal lying in sump?
Does the engine turn? (hand cranking)
I think I would like to find out what caused this!
www.sas.org.uk
www.the-ace.org.uk
« Reply #2 on: 07 April 2009, 09:51 »
if its a 1y, aaz or 1z engine the baffle costs 4.64 from VW '055 115 221B'
Offline *tell*
« Reply #3 on: 07 April 2009, 19:05 »
its a 1z.
only took the sump off to have a look and found alot off plastic.
replaced the sump gasket and refited without baffle.
i may have to take apart again then  :cry:
Offline Ben Lessani
« Reply #4 on: 07 April 2009, 23:42 »
The baffle is to stop oil from sloshing about and the pump running dry.
It's held on by 4 little clips around the pickup, they are easy to break when removing - maybe someone has had the pump off before and broke a couple and weakened it, then some stripped driving has just broke it loose altogether.
Personally, I'd fit a new one, or a nice Shrick baffled sump  :drool:
Offline *tell*
« Reply #5 on: 08 April 2009, 21:00 »
ordered baffle from vw should get tomorrow  :laugh:
just got to take sump off again  :embarassed:
thanks all
Offline Ben Lessani
« Reply #6 on: 08 April 2009, 21:15 »
Is your sump seal new? Worth throwing a new one on it whilst you're at it, GSF do the metal/rubber hybrid for about £9.
