Author Topic: Wobbly when driving!  (Read 3347 times)
Offline Martz
« on: 06 April 2009, 18:31 »
My project Ghetto is being a little bit of a bum hole! When I am driving along and get to about 40mph, the rear end is all over the place and feels like it is going to break! Scares the life out of me. I have changed the suspension over but this has had no effect?  Any ideas on what else I need to do to resolve this issue, I was thinking of maybe the bushes? Any ideas would be good.
Martz :cool:
Offline Ben Lessani
Re: Wobbly when driving!
« Reply #1 on: 06 April 2009, 18:36 »
The back end's skittish?
Binding rear brakes
Front / Rear ride heights different
Worn rear beam bushes / Poly bushed rear (Poly bushes at the back are notorious for firming up the rear and making it lairy)
Worn rear strut top mounts (cone rubber affairs)
Bald tyres / Mismatched directional tyres / Directionals wrong way round (look for INSIDE or ROTATION)
Bad wheel balancing
Loose / Worn wheel bearing
Incorrect toe / camber
Pick one ;)
Offline Martz
« Reply #2 on: 06 April 2009, 18:45 »
Binding rear brakes
Bad wheel balancing
Pick one ;)
Cheers, will inspect the other options.  :wink:
Offline Mr Blue
« Reply #3 on: 06 April 2009, 20:30 »
sup Martz :cool:
Does the back end bounce around roundabouts with pot holes?
Mine does and ive narrowed it down to worn axel bushes. Missions to change so ive heard.
Offline Martz
« Reply #4 on: 06 April 2009, 20:38 »
sup Martz :cool:
Hey mate
Nah, it just wobbles and feels like the wheels are about to come off???????
Offline Ben Lessani
« Reply #5 on: 06 April 2009, 21:03 »
Then I'll add ..
Loose wheel nuts
Wrong size spigot on wheel
Buckled wheel
Flat edge on tyre
Offline johnson6672
« Reply #6 on: 06 April 2009, 21:17 »
I would find the problem asap, had a rear wheel bearing collapse on me on the motorway doing 70+ ended up in the crash barrier, not fun!
MK4 GTI T AGU, REVO Remap, BMC carbon box, Miltek cat back, Forge diverter valve, THS FR3 engine/Gbox mounts, Some random alloys, lowered on coilovers.
192bhp 212lbft torque.
Offline Martz
« Reply #7 on: 06 April 2009, 21:25 »
Then I'll add ..
Loose wheel nuts
Buckled wheel
Flat edge on tyre
Definately none of the above Ben.
The car is not being used at the moment and I won't drive it until I am happy with it. Not into hospital food tbh, although if I was with BUPA it would not be to bad! :D
Offline OakeyDoak16v
« Reply #8 on: 07 April 2009, 01:17 »
Binding rear brakes
Bad wheel balancing
Pick one ;)
Mine was the same till i replaced the rear beam bushes. Check them? :smiley:
Offline edpryce
« Reply #9 on: 10 April 2009, 12:27 »
when you say check the rear beam brushes - what are you looking for? the pot hole bouncing sounds simlar to mine
