Author Topic: Hard to start and rough idle - 1.8T AGU with Induction kit just fitted.  (Read 4500 times)
Offline sarahs_gti
Just fitted an induction kit to the wifes car and it is now hard to start unless you give the go pedal some gas when turning the key, then it keeps idling really rough like its hunting. Mind you it did this since we bought it but seems to be a bit worse now, could it be something to do with the sensor that was connected to the OEM airbox - thats still plugged in just moved out of the way?
Thanks.
'99 1.8T GTi 5dr - Tropic Orange | 18" TT Quattro Sport Rims | Full Cream Leather Interior | 4Motion Valances | -35mm Jamex Suspension | Forge SPLT-R | VR6/G60 Clutch/Flywheel |
******NOW FOR SALE******
Offline dai-cymru
  • 1989 MK2 16V
put the oem airbox back on see if it cures it, could be the maf sensor try unplugging it see if its better
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
I'd say MAF has finally given up due to the new induction kit...
Offline Voodoo-Music
Not sure how it was fitted but a good thing to check is the battery connection. If the battery was removed then the car will idle badly and wont start well if the connections are slack. Also MAF sensor lol
Offline kuvalee
  • Approved vag painter since 1999
This happened to me  with a k&n typhoon kit, car ran but sounded like a tractor!! So I took the kit off and put the oem air box back on smoothed with the r32 dsg intake and a piper cross panel filter now it runs sweet as a nut!
Offline sarahs_gti
Just remembered I had the door panel off to change the door lock and the battery ran flat coz i had the doors open and radio on, so it might be down to the car not being run properly yet - only done 1.5 miles since the battery was put back on.....
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
I'd give the battery a proper charge up, as it takes about 500 miles of diving to get it fully charged that way! ;)
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
Offline topher
  • Administrator
  • fully functioning
Thanks.
That's no sensor, that's your ignition amplification module. If you've knocked a wire on that or have stuck it somewhere giving it a dodgy earth you could have the symptoms you describe.
Offline turbo.jon
  • mk4 1.8t agu
Had same thing with mine today fitted filter yesterday and it was fine and this morning on way to work to was ok but when i come out work it took while to fire up which its never done before fitting filter.
Did you manage to sort it out?
jon
