Author Topic: gti 16v middle silencer  (Read 2096 times)
Offline coggers79
« on: 05 April 2009, 18:49 »
i have a 96 gti 16v which makes an awful resonating noise when cold, this is coming from the middle silencer but when warm goes off ive had it checked out as i thought the baffles were gone but there are no rattles from it, sometimes the car feels as if it is holding back should i get a new one or can i bypass the silencer with a straight pipe if so what will happen the silencer is the one which runs along the axle
Offline dannydubs
  • mk2 gti,mk3 wagon,mk5gti
Re: gti 16v middle silencer
« Reply #1 on: 06 April 2009, 17:57 »
i  got a straight through pipe from halfords 4 50 quid mate a big difference
.....the project.........
Offline Pauly C
  • Its only a GTI, but I like it!
« Reply #2 on: 16 April 2009, 18:51 »
Mine does that too, its 95M 16v'er, but its only does it whilst its ticking over @ 1000rpm. Anyone know if the 8v & 16v back & middle boxes are interchangeable???
Offline coggers79
« Reply #3 on: 16 April 2009, 19:10 »
im getting it replaced next tuesday for a straight thru piece of pipe for 40 quid is this a good idea
Offline shepgti
« Reply #4 on: 16 April 2009, 19:21 »
if you like it noisey then yeah. as for the other comment: on the whole the 16v system is a larger diameter than the 8v
Offline ace
« Reply #5 on: 16 April 2009, 19:27 »
as shep said, will make it louder, had a straight thru on my old 8v altho i had a s/s manifold and de-cat as well, was very loud when i put my foot down. the 16v are a larger diameter than the 8v, they have the same size bore as the vr's
Offline coggers79
« Reply #6 on: 17 April 2009, 09:25 »
will it give my car more go and will it pass its mot with no silencer
Offline Len
« Reply #7 on: 17 April 2009, 09:44 »
Different diameters I believe so no not interchangable.
www.sas.org.uk
www.the-ace.org.uk
Offline Pauly C
« Reply #8 on: 17 April 2009, 11:50 »
Cheers guys, thats what I was afraid of, I thought the offer was too good to be true!
So then, anyone know anyone getting rid of a middle and back box for a 95 GTI 16v????
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« Reply #9 on: 17 April 2009, 12:10 »
Just taken one to the scrappy   :undecided:  Does the straight through make it much louder with a stock back box?  when  did it on my 1.4 it made no diffrence, i know its kinda diffrent,  tempted to get one for my valver.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
