Author Topic: Rear caliper handbrake overhaul  (Read 19984 times)
Offline midz16v
Re: Rear caliper handbrake overhaul
« Reply #20 on: 06 April 2009, 12:29 »
i have a set of rear calipers u could have if u want them,there in fife though and i'm no sure if there for a mk2 or 3
Offline Conker
« Reply #21 on: 06 April 2009, 12:42 »
...Better cost:benefit analysis needed, Ben.
Hehe, May I recommend that you add  :rolleyes:,  :huh:, or  :smug: to take this to the next level of patronising.
:grin:
Offline Ben Lessani
« Reply #22 on: 06 April 2009, 12:49 »
Hoop de blah, blah blah blah, something about my tall horse.
Man-up and do the job properly.
I know new calipers are easier to fit, but if someone here had some experience of fixing the weak handbrake - ie. just cleaning up a part of the mech to fix it, then it would be substantially easier, quicker and cheeeeeeeper!
Ps. Stop saying man-up :lipsrsealed:
@ midz16v
They look like MK3 units, can't see an exposed spring anywhere. You're a good 80 miles from me - what monies do you want for them?
Offline midz16v
« Reply #23 on: 06 April 2009, 14:49 »
nowt mate thats how much they cost me
Offline Ben Lessani
« Reply #24 on: 06 April 2009, 17:52 »
Just a quick one, what stops you using the MK4 calipers with a solid brake line from the M12 fitting on the caliper to M10 on the car? What movement is there between the caliper and the rear beam?
Offline Diamond Hell
  • Opinions я Us
« Reply #25 on: 06 April 2009, 17:59 »
Although you're very small from my tall horse, I think you'll find that you're talking about a sliding caliper set up.
That's why you need to fit a flexible hose, because the caliper slides thus it moves, see - hard lines will fatigue if put in this situation.
Now, man-up and get on with the job, Lessani.
Offline Ben Lessani
« Reply #26 on: 06 April 2009, 18:25 »
Pffftftftfttt :tongue:
Only reason I'm messing about is
1. because I'm cheap,
2. because I'm cheap,
3. I have 1 more day to get the MOT retested!
Right, tell you what. I grabbed a pair of MK4 units from the scrappers today. I don't have time to wait on delivery of the crappy adaptors, so I pinched a couple of rubber flexi's from a motor factor friend 10mm female to 10mm female.
I was thinking, as a quick hack for the MOT (and probably for the rest of time because I'm lazy). I can flare 12mm male and 10mm male fittings onto a mini length of brake pipe, thread that into the caliper and then thread the flexi onto the standard fittings.
Is there any real dodgyness doing it this way?
  • Opinions я Us
« Reply #27 on: 06 April 2009, 19:32 »
 :undecided:
I don't *think* so - some installations of the 280mm front brakes (those you're too cheap to fit to your car) have a short section of hard-line before the flexi.  The important thing is to allow the caliper to slide, with a flexi-hose taking up the slide, not a hard-line.
Offline Ben Lessani
« Reply #28 on: 06 April 2009, 19:52 »
Basically, something along the lines of that.
If I can find a place which sells a banjo > 10mm male, or any 12mm to 10mm fitting, then I'll be sorted - after all, that's all that's in the goodridge pack.
« Last Edit: 06 April 2009, 20:00 by Ben Lessani »
Offline Conker
« Reply #29 on: 06 April 2009, 20:59 »
:undecided:
This post doesn't count - You didn't say "man-up".
