Author Topic: What have you done to your Golf today?  (Read 1112411 times)
Offline viperjsy
Re: What have you done to your Golf today?
« Reply #7060 on: 13 August 2015, 15:36 »
put on a engine heat shield
Offline viperjsy
« Reply #7061 on: 10 September 2015, 13:11 »
just changed my air filter and heat shield for this
Offline Mr_Orange
« Reply #7062 on: 12 September 2015, 08:30 »
Dropped off at garage for oil+filter.
Also have minor abs problem needs diagnosed and fixed. Its an intermittent signal so either the sensor, abs ring or wiring.... :-(
Build thread clicky
Offline Addictedtodubs
« Reply #7063 on: 16 September 2015, 00:57 »
Swore at them today mostly😡🍁😎😍
Offline Mr_Orange
« Reply #7064 on: 19 September 2015, 12:34 »
Turned into a mammoth fault finding session that cost me £££s. Including time and parts on what turned out to be a blown fuse... Seems fuse #5 throws brake switch fault code and oil level sensor fault on dash!  :-/
Build thread clicky
Offline Antfisher187
« Reply #7065 on: 05 October 2015, 20:40 »
Not posted in a bit so have done quite a lot since last post car now looks like this
Offline Mr_Orange
« Reply #7066 on: 10 November 2015, 22:24 »
Emptied oil catch can >:)
Build thread clicky
Offline viperjsy
« Reply #7067 on: 20 November 2015, 19:53 »
Had thre cam belt changed and water pump and aux belt
Offline bgbazz
  • If it aint broke...I can fix it!
« Reply #7068 on: 16 December 2015, 14:30 »
Picked a full set of wind deflectors for the side windows. Will be fitting them and a set of seat covers tomorrow.
Mk4 Golf TDI Estate 4Motion, remapped 1.9. Sweet runner = keeper. She is the 66th vehicle I've owned and hopefully, the last.
Offline pickles
  • Next!!!
« Reply #7069 on: 23 December 2015, 19:06 »
New VR6 clutch with ABF SM flywheel bolted on today, only took us about 6 hours which i reckon aint too bad considering it was a right pain.
weirdos on here i tell you ;)
mk4 golf 1.8T, AGU, CAI, Forge007p DV,TIP,Decat, Bilsteins with Koni springs dropped 40mm
Mapped
Nearly S3 time  :)
