Author Topic: What have you done to your Golf today?  (Read 1112418 times)
Offline clancy
Re: What have you done to your Golf today?
« Reply #6860 on: 22 May 2014, 22:39 »
Removed coilovers, cut bump stops in half and re adjusted the heights on them then re greased the threads
Sprayed my rear badge black
Wired up my r32 style headlights so the centres run orange with the side lights on
New load of oil
Oh and worked out what the burning smell was, my tyre sat against the coilover on the front left, had burnt about 7 mm into the sidewall haha. So ordered some spacers which should be here tomorrow
MK3 GTI 16v
Offline DCmk3
« Reply #6861 on: 22 May 2014, 23:31 »
Not everyone's taste but it's different.
2014 Mk7 GTI - Littco L500
Offline viperjsy
« Reply #6862 on: 23 May 2014, 11:36 »
just receved my forge 008 and fitted
Offline shaft69
« Reply #6863 on: 24 May 2014, 18:26 »
Fitted my cambelt and water pump found engine mounting split so just ordered vibratech mounts both sides from awesome gti. Also ordered engine spacers sumps keeps catching speed humps.
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline Jarrold06
« Reply #6864 on: 24 May 2014, 18:37 »
Just changed the decat for a cat sorted out the back box and just brought all cv boots to change in the week ready for the mot
Offline northeast_gti-t
  • "1.8T AGU"
« Reply #6865 on: 24 May 2014, 18:43 »
Fitted another door alarm led to the passenger door seeing as i had a spare one  :laugh:,picked up a headlight/instrument cluster dimmer switch from a local breaker as mines not illuminating  :whistle:
« Last Edit: 25 May 2014, 18:18 by northeast_gti-t »
2000 Mkiv GTi 1.8T AGU
Offline 1.8Tgolf_Chris
  • Mk4 1.8t AUM
« Reply #6866 on: 26 May 2014, 21:38 »
Fitted my coilovers with new top mounts, drop links and wheel spacers a successful day - pictures tomorrow when it actually stops raining :cool:
  • "1.8T AGU"
« Reply #6867 on: 28 May 2014, 20:11 »
Picked up my octy vRs steering wheel and fitted  :smiley:
Offline spikenipple
« Reply #6868 on: 28 May 2014, 21:25 »
Smoothed the engine bay....
Offline boneybradley
  • Back in a Mk3...
« Reply #6869 on: 28 May 2014, 21:44 »
Built another (well started)  :cool:
