Author Topic: What have you done to your Golf today?  (Read 1112424 times)
Offline northeast_gti-t
  • "1.8T AGU"
Re: What have you done to your Golf today?
« Reply #6670 on: 20 November 2013, 14:03 »
Sorted out the vibrating centre section on the exhaust,all good now and fitted my dogbone mount polybush,vast improvement now  :smiley:
2000 Mkiv GTi 1.8T AGU
Offline spudboy6
  • Just like a golf ......
« Reply #6671 on: 20 November 2013, 23:26 »
Cylinder head skimmed to up compression very slightly , ecu chip fitted , rear lamp gaskets re sealed to stop bot filling with water , put red LED in dash for my alarm unit polished my wheels and now to rebuld the head and get it back together for the weekend
Offline CraigBest
  • Golf Gti Mk3 Colour Concept Flash Red
« Reply #6672 on: 21 November 2013, 18:29 »
Used doubled sided sticky pads to put my front wheel arch by on my mk3 gti due to the dreaded rust.
Same again today different corner tho  :sad:
Offline ski21
« Reply #6673 on: 22 November 2013, 20:49 »
fixed the sketchy choke cable on my new weber  :smiley:
  • "1.8T AGU"
« Reply #6674 on: 01 December 2013, 20:31 »
Bit of a list as i have done a few jobs in the past week  :grin:
replaced the knackered aux belt,binned my old fooked back box and replaced with my almost new standard one won on e-bay for next to nowt,fitted the remaining bits of interior trim that was missing!,replaced a dodgy thermostat for a genuine o.e.m one :rolleyes:,replaced both track control arms and ball joints along with the anti-roll bar bushes,which then on th o/s the driveshaft popped out  :shocked: discovered it had been fitted the incorrect way round and was missing the securing circlip  :sick: (now i know why it clunked/knocked from the front end  :angry: changed the dog-bone mount for a powerflex one and replaced the dried out cv joint(gearbox) all that done then discovered a grinding noise from drivers side front wheel area  :angry: which led me to replace the front discs and pads yesterday,due to a fooked o/s disc,Still on a better note after all this i now have better front brakes and no grinding  :smiley: and now now knock/clunk from the front end/gearbox and a much improved gearchange and firmer front end  :smiley:....happy days.....next job sort out the missing multi-plug that previous owner(s) have decided to cut off from the brake pad wear warning sensor.....thanks for that you bellends  :rolleyes: and that's pretty much all.
Offline boneybradley
  • Back in a Mk3...
« Reply #6675 on: 03 December 2013, 21:19 »
new ecu temp sensor fitted (with minimal anti freeze loss)
I also visited a local spray shop and the guy is a serious vw nut (he run's a 1.8t Mk2) and we have agreed price on some needed remedial work for mine!  :cool:
Offline Screech16v
  • MK3 20vt AGU
« Reply #6676 on: 04 December 2013, 23:01 »
Just purchased a new wing in preparation for respray over the xmas period
  • "1.8T AGU"
« Reply #6677 on: 06 December 2013, 22:19 »
located the wires and plug on etka for the brake pad wear sensor and ordered from vw,activated seat belt warning light and fitted another head unit  :smiley:
  • Back in a Mk3...
« Reply #6678 on: 08 December 2013, 16:54 »
Filled mine with 2.5 litre's of oil!! (I guess my leaky oil cooler seal is proper bad now!)
Offline Screech16v
  • MK3 20vt AGU
« Reply #6679 on: 08 December 2013, 17:13 »
Changed front top mounts, cleaned the threads and collars on the coilovers then white greased them ready for winter, raised it all round by and inch,attempted to change both handbrake cables and realised I had the wrong ones after I had destroyed one getting it off,so only have one cable now until I can get a pair of correct ones.Will be sorting out my winter wheels next week.
