Author Topic: What have you done to your Golf today?  (Read 1113039 times)
Offline DanChave
Re: What have you done to your Golf today?
« Reply #6090 on: 30 October 2012, 23:13 »
More wiring checks, trying to get power to the ISV plug :(
Offline pickles
  • Next!!!
« Reply #6091 on: 31 October 2012, 14:55 »
lost my steering on the way home from work  :sad:, track rod end had popped of the tie rod, managed to get it home, gna change the tie rod directly, ahhhhhhhhhhh one thing after another NEXT!!!
weirdos on here i tell you ;)
mk4 golf 1.8T, AGU, CAI, Forge007p DV,TIP,Decat, Bilsteins with Koni springs dropped 40mm
Mapped
Nearly S3 time  :)
Offline JC
  • Back in the North.
« Reply #6092 on: 31 October 2012, 22:07 »
Taxed it ready for show season  :huh: :lipsrsealed: :whistle:
Offline Jamesl94
  • YUUUUUUUUUUUUUUUUUP
« Reply #6093 on: 01 November 2012, 02:35 »
Made a square peg fit in a round hole
Offline Lewy
« Reply #6094 on: 01 November 2012, 10:16 »
Been there, done that!  :laugh: :laugh: :laugh: :laugh: :lipsrsealed: :rolleyes:
Offline MS1COYS
  • Alfie 'H' 10-09-11
« Reply #6095 on: 01 November 2012, 14:00 »
Got seriously f**ked off with it! Got an aggressive misfire and idle is as lumpy as my ballbag. Either coil packs or plugs I presume  :sick:
292bhp / 287lbft
Offline DCmk3
« Reply #6096 on: 01 November 2012, 14:16 »
Tried to save it from the garage, but I can't get in because the hinge has bent..  :undecided:
2014 Mk7 GTI - Littco L500
Offline MS1COYS
« Reply #6097 on: 02 November 2012, 14:28 »
Cylinder 4 fault - Coilpack and spark plug thoroughly f**k*red!
All coil packs replaced and a brand new set of NGK platinums.
Problem solved.
Ps. The 3 existing 'good' coil packs are in the boot for safe keeps!
Pps. The coil pack in the photo has a serial number of (VW AG 07K 905 715). According to the web these aren't even the correct ones for my engine model and yet they are the ones that VW put in, when my car went in for the initial recall. wayne kerrs! The Bosch ones I have replaced them with seem altogether more sturdy and have a rubber sleeve that comes all the way down to the tip of the spark plug, so hopefully no moisture will get into these and render them useless!
« Last Edit: 02 November 2012, 14:39 by MS1COYS »
292bhp / 287lbft
Offline whileoceanasleeps
  • patience comes to those who wait.
« Reply #6098 on: 02 November 2012, 18:48 »
refitted the resprayed grill, wound the coilies lower on the back to match the front, refitted the oem steering wheel while i wait for the boss for my momo one and fitted some 100w bulbs and it is b-right
Offline Mr_Orange
« Reply #6099 on: 02 November 2012, 20:20 »
Looked at some new panel damage in daylight.  Some old twit decided to get up close and personal with the rear quarter yesterday morning.  Nothing too bad for me, surprisingly.  German engineering beats little granny shopping box thing!
Build thread clicky
