Author Topic: What have you done to your Golf today?  (Read 1113046 times)
Offline Hurdy
Re: What have you done to your Golf today?
« Reply #6040 on: 06 October 2012, 20:32 »
Went Revo stage 2+ in the Golf R, full Milltek exhaust with black ceramic tips, RS4 high pressure fuel regulator valve and Autotech HPFP. Dyno'd at 356bhp and then tested a 0-60 run with the Racelogic Performance Box at 3.5 seconds!!
Very impressed and the car feels über fast. :cool:
Can't wait to get the direct port water meth system fitted!  :laugh:
Seat Leon Cupra Black 290 DSG
Offline Jimble
« Reply #6041 on: 06 October 2012, 21:05 »
Jebus! Makes me givin it a damn good clean look a bit sh!t :laugh:
Offline Khare
  • The bear that khares
« Reply #6042 on: 07 October 2012, 14:26 »
Changed blown rear number plate light, lowered the front a bit and adjusted the handbrake cables.
Offline rich1977
« Reply #6043 on: 07 October 2012, 18:36 »
fitted rear wheel bearing and sorted that went to change the pads on drivers side and sheared the calliper pin  :whistle: :whistle: :whistle:
Www.Internet-ink.co.uk voucher code RL15 for 15% off all pens,toners and ink cartridges including cannon Epsom dell and hp.
Offline MS1COYS
  • Alfie 'H' 10-09-11
« Reply #6044 on: 08 October 2012, 01:33 »
Had an oil change, oil filter, engine flush and oil fortifier done. Brake pads cleaned. And had air con sterilised an de-odorised !
Happy f**king days!
« Last Edit: 08 October 2012, 02:07 by MS1COYS »
292bhp / 287lbft
Offline whileoceanasleeps
  • patience comes to those who wait.
« Reply #6045 on: 08 October 2012, 22:23 »
Got two air plastic tubes from the scrappy and made a cheap twin cold air feed from below the bumper to the K N cone on my mk3 8v :)
Offline Diamond Hell
  • Opinions я Us
« Reply #6046 on: 08 October 2012, 22:33 »
Today I did 540degrees in my Golf.
And a tyre.
And a rim.
And a petrol pump.
And a suspension strut.
And a control arm.
And other miscellaneous items.
And got back out driving it.
Offline JC
  • Back in the North.
« Reply #6047 on: 09 October 2012, 19:54 »
And a tyre.
And a rim.
And a petrol pump.
And a control arm.
it was at 100 mph too, thank fook for fat bast4rd passengers  :whistle:
 :kiss:
Offline Mrs kempie
  • *Takes on role of nagging wife*
« Reply #6048 on: 09 October 2012, 20:24 »
explain?
today i took alot of rust off the driver door and added some gti wheel trims
Offline ramrod
« Reply #6049 on: 12 October 2012, 19:22 »
Checked the oil, topped up screenwash & checked brake fluid level, no top up needed.
Changed the front discs, took the calipers off & gave them a good clean with a wire brush & greased them right up & slapped new pads in :laugh: The new one's had no brake wear sensor but the original one's did but they were not connected up (no light on in dash but is present) & i could not see/find where they would plug into? Just a wire for the abs sensor unless i am going blind?
I have the ATE system on my anni, ECP stock's Lucas & ATE caliper's when i put my reg number in, so i never ordered one but i saved myself some coin by just cleaning & greasing the original caliper :whistle:
Attempted to fit another set of locking wheel nuts but the thread was too small, so will be sending them back!
rear discs, pad's & brake fluid change on the to-do list as it started to rain :nerd:
*I had a little help from a friend to do the above, I am learning :tongue:*
Mk6 Gti - current daily
Mk3 16v Anni - retired daily now parked on 200,300 miles
