Author Topic: What have you done to your Golf today?  (Read 1111541 times)
Offline Neo Badness
  • Feet are for pedals
Re: What have you done to your Golf today?
« Reply #5810 on: 04 July 2012, 20:41 »
Moved it out of the unit, then back in again.
Offline lemski
  • 16v
« Reply #5811 on: 04 July 2012, 21:57 »
Got a little bit of time to sort the mk4 shifter out. Nearly inplace
Offline brett
« Reply #5812 on: 05 July 2012, 17:31 »
not a lot lol,air filter,pollen filter and fuel filter
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #5813 on: 05 July 2012, 17:39 »
Took the wife's MK2 for a MOT - Flew Through....  :laugh: :laugh: :laugh:
For More Info Click To See;
Offline lemski
  • 16v
« Reply #5814 on: 05 July 2012, 19:07 »
Fitted mk4 shifter, catch can. And routed all wiring
Offline s-l-i-x
  • Golf MK4 1.8T AGU
« Reply #5815 on: 05 July 2012, 19:22 »
Was going to remove the cat heat shield as it was a job from ages ago, but on inspection, it has already been ripped off  :laugh: so just had a cuppa instead.
Offline scarr89
  • Mk4 Golf, DERV FTW!
« Reply #5816 on: 05 July 2012, 19:27 »
Oil and filter change in the pissing rain, with my trusty new massive oil drip tray I took home with me after the Harriers were stripped down and sent to the Americans.
They are quite possibly the handiest item have to floating around the garage  :wink:
Offline mcgee9t2
« Reply #5817 on: 05 July 2012, 20:14 »
easiest job ever :grin:
Offline Scott D
« Reply #5818 on: 05 July 2012, 23:43 »
fitted mikalor clamps on the chargepipe and intercooler hoses, shouldn't end up on the hard shoulder botch repairing blown off hoses again  :grin:
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline Neo Badness
« Reply #5819 on: 06 July 2012, 00:31 »
Noticed that someone has damaged the front bumper and smashed the rear light whilst it's been parked outside my unit.  :evil:
