Author Topic: What have you done to your Golf today?  (Read 1113028 times)
Offline antogoof
  • bbm mk2 g60
Re: What have you done too your Golf today?
« Reply #540 on: 20 June 2009, 21:59 »
thought about how much i have spent on ebay recently.....ouch!
polybush kit
16v brakes
bottom arms
ball joints
wheel bearings
rear discs and pads
air tools for all the above!
gotta stop spending now, going on holiday soon!
and i still need bloody tyres!!!! :shocked:
mk2 bright blue met bits wanted in north west.
Offline Thom89
  • Looking for an "Icebreaker"
« Reply #541 on: 21 June 2009, 01:50 »
Fitted new exhaust, changed power steering fluid, changed gearbox oil, and waxed to death  :wink:
Tom
Offline tweed
« Reply #542 on: 21 June 2009, 14:55 »
Finally got round to fixing the master cylinder. Got it apart to find out I have a 23mm bore but, I ordered 22.2mm bore seals :( not happy.
Offline Khare
  • The bear that khares
« Reply #543 on: 21 June 2009, 16:24 »
modified air box even further.
Turned the holes into cut out sections, and also rather than direct the cold air intake to the original intake, I made another cut out for it, so now its got the original intake hole (without the trumpet) and its also got the cold air intake above it. Sounds much louder and throttle seems a bit more responsive.
Offline tweed
« Reply #544 on: 21 June 2009, 16:54 »
What car do you have? sounds like a plan. and where have you put your cold air feed?
Offline Khare
« Reply #545 on: 21 June 2009, 17:00 »
I'll get pics and post them up in the mk3 section dude.
gti 8v.
Offline Guy
« Reply #546 on: 23 June 2009, 16:20 »
bought a shed load of spares yesterday
fitted new fuel pump relay (the correct one!) today  :smiley:
Offline gjroe78
« Reply #547 on: 23 June 2009, 16:24 »
Nowt as its raining again  :sad:
Offline AlanD
  • MK5 2.0T 16v
« Reply #548 on: 23 June 2009, 16:29 »
Not a cloud in the sky, cant wit for the drive home from work today. 30 minute and counting ! :D :cool:
Offline tweed
« Reply #549 on: 24 June 2009, 11:32 »
Went to buy a green cotton panel filter, they wantede about £63, laughed that off. Got a 60mm cold air feed, so I can cut a hole in the air box now. Ordered a new brake master cylinder, that should be here tomo.
