Author Topic: What have you done to your Golf today?  (Read 1113337 times)
jockgti
Re: What have you done to your Golf today?
« Reply #5370 on: 15 March 2012, 17:25 »
did the gear box lever alignment on my mk4,fixed my 112 and 249 resistors as they had came loose and were throwing up cel's
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #5371 on: 15 March 2012, 21:22 »
Finally got my carrier bolts off and new brakes on...with rubbing.  :undecided:
Offline GTI:Gibbo
« Reply #5372 on: 15 March 2012, 22:34 »
Changed cv boot and give wheels a wipe over.
Offline search
« Reply #5373 on: 15 March 2012, 23:34 »
Tint my ride. (Didn't do a good job but not a bad job either.) £6 off ebay cant complain. but will be getting it all done from a pro when i can aford it.
Golf mk3 1.4 (sold)
Golf mk2 1.3 (sold)
Golf mk3 1.6
Offline sychosis
« Reply #5374 on: 16 March 2012, 09:45 »
Mine did this for about a week
« Reply #5375 on: 16 March 2012, 10:03 »
For some reason there doesn't seem to be enough tolerance between the ABS ring and sensors. I took it for a longish drive last night and it appears to have bedded in a bit and the rubbing noise is starting to go.
« Reply #5376 on: 16 March 2012, 21:08 »
Are those front tints legal?
Offline search
« Reply #5377 on: 16 March 2012, 22:24 »
yeah its the lightest smoke.
Golf mk3 1.4 (sold)
Golf mk2 1.3 (sold)
Golf mk3 1.6
Offline Deano2711
  • 1992 VR6
« Reply #5378 on: 16 March 2012, 22:33 »
I had new discs and pads fitted recently and it came out of the garage grinding (like a metal on metal sound). I took it back to the garage who fitted them who apparently did nothing and now it's back it's great.
Offline mk2addict
« Reply #5379 on: 17 March 2012, 18:54 »
Sorted out ht leads so my freshly done abf conversion is now firing on all 4 cylinders ha. Um cleand about a ton of old 8v bits and tools out of her as she's been storage for it all as I've been doin the swap. Put fuse box back together and dash back together. Ran a wire from coil pack to fusebox for my original rev counter to work. Ran a wire from ecu to diagnostic plug as I accidentally cut the wire needed and wrapd it up opps. Umm stood back and admired and waiting to take it out
