Author Topic: What have you done to your Golf today?  (Read 1111545 times)
Offline AlexMozza
Re: What have you done to your Golf today?
« Reply #4920 on: 10 December 2011, 15:59 »
Bled brakes, got ABS back  :cool:
2001 Satria GTi
Mini 25 Special Edition 1984 998 :D
Formula 3 Mechanic
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #4921 on: 10 December 2011, 16:39 »
Replaced Power steering pump on the Mrs MK2....
Bloody Messy Job!
For More Info Click To See;
Offline RnP
  • Audi S4 gone, looking for b5 rs4
« Reply #4922 on: 10 December 2011, 16:48 »
added california scent cherry to the mk4
Offline DanChave
« Reply #4923 on: 10 December 2011, 19:58 »
Picked up my Porsche Cups :)
jockgti
« Reply #4924 on: 10 December 2011, 20:41 »
Today i finally got round to removing the rocker cover,inlet manifold,249/112 valves,throttle body and for all the folk thinking of doing it its not an easy as some would say,even threads I've found on vw vortex didn't explain everything,i had wires in places nobody had mentioned,i asked in the other thread about anything underneath the inlet and was told there's nothing underneath yet i had 4 hoses to remove(aum),the old gasket for the rocker cover snapped into pieces it was so brittle,tomorrow i'm getting on with the sanding and painting,couldn't believe the state of some of the bits,i'll let the pics do the talking
Offline daz veedub
  • Operation 1.8t bolf
« Reply #4925 on: 10 December 2011, 21:15 »
you,ll notice the difference once that tb is clean  :wink:
good work jock  :cool:
Offline lemski
  • 16v
« Reply #4926 on: 10 December 2011, 21:17 »
Sanded, fillered, sanded and painted. Then put it back together. Update later
jockgti
« Reply #4927 on: 10 December 2011, 21:30 »
so on an aum is it the flat bit across the middle of the tb i can't touch? was gonna do the pcv edit but all the how to's i've seen have a slightly different setup to mine and i'm not 100% sure so i'm leaving that just now
Offline daz veedub
« Reply #4928 on: 10 December 2011, 21:31 »
the butterfly  :wink: if u open it will need setting up again with vagcom i beleive
jockgti
« Reply #4929 on: 10 December 2011, 21:43 »
ok i'll try not to touch it lol
