Author Topic: What have you done to your Golf today?  (Read 1111197 times)
Offline Khare
  • The bear that khares
Re: What have you done too your Golf today?
« Reply #30 on: 03 April 2009, 23:16 »
put petrol in it and drove it to college...and bashed out choonez with my new sub amp and headunit  :cool:
Offline bobbito
  • Hammer and Chisel Engineering
« Reply #31 on: 03 April 2009, 23:42 »
Not today but recently bought this from a vento
and took them apart so the material all matched in my golf
In the last 7 months its had
-coilovers
-up rated 22mm front and rear H&R ARB's
-BBS RX11's
-De-arched
-Smoked headlights
-Slim cl side strips
-Front and rear drilled and vented discs + green stuff pads
You would think, as I get through the list of things to do, it would get shorter but unfortunately......
« Last Edit: 03 April 2009, 23:48 by bobbito »
Offline Adam
« Reply #32 on: 04 April 2009, 01:33 »
Are they worth it? On the edge of buying them....much of a difference?
Down Hill From Here.
Offline MrClifford
  • mk3 golf GTi 8v
« Reply #33 on: 04 April 2009, 01:50 »
i got tinnitus from my old sub, gladly after 4 months without it no more ringing in my ears! now im at 2 front doorspeakers :(! o well less weight i spose lol.
btw today i: delivered my meals, went 2 the missus, drove bak home, and a trip to the petty station 2moz!
coming soon ;)
Offline monzablue16v
« Reply #34 on: 04 April 2009, 12:28 »
Got some work done on the project yesterday :)
More work done recently, lots of messing about trying to get the coolant pipes to run properly and oil pipes for the turbo in, these are now sorted bar the shouting and my new intercooler arrived along with some silicone hoses, so I am now onto running and planning boost hoses and mounting the intercooler.
I had to put the grill on to check the centre spots still fit with the intercooler in place which has made me want to finish it soon. :)
16v Sump is now fitted and also has the oil return in. need to make a bracket to hold the alternator in a different position so it clears the throttle body.
Got some twin pot 280mm S2 brake calipers and carriers so building those up and just hoping they will clear the inside of my wheels :)
Got a bracket missing from the gearbox, need to go hunting around scrapyards.
ECU is delayed so not going to make Elsecar hoping to have it ready for Big Bang at the end of April.
Offline laurielaeks
« Reply #35 on: 04 April 2009, 12:37 »
i Fitted a set of Mk4 polo coilovers to my golf lol, had to change the strut top mounts on the front to the golf ones and they fitted perfect (and really low)
but when i came to the back coilovers :sick: they were way to small so had to use the standard ahocks n springs on the rear, the gti looks like stilts at the rear right now,
ordering a full proper mk3 golf coilovers today lol
anyone want to buy some front coilovers or sell me some rear ones? lol
Offline 01664gti
  • mk3 hatch mk3 wagon and mk2 16v
« Reply #36 on: 04 April 2009, 12:47 »
I have spent the last week trying to find a front engine mounting bracket for my 16v so i can come out to play lol :cry:
Offline bobbito
« Reply #37 on: 04 April 2009, 13:31 »
If you can find them cheap enough then I would do it but not for near £300 as I think they are. I got mine for £120 nearly new off ebay.
Offline Woxy
« Reply #38 on: 04 April 2009, 13:54 »
Put my new headlights in after some messing about with the wiring fecking fleabay
Now just to sort out the fogs and reflectors
Offline boneybradley
  • Back in a Mk3...
« Reply #39 on: 04 April 2009, 14:29 »
well I've being undermine looking at the dents it got on thursday...oh and after grounding my abs light is on constantly!! fkin shi77y roads and speed mountains!! best get it vag-commed i suppose!
