Author Topic: What have you done to your Golf today?  (Read 1112263 times)
Offline JC
  • Back in the North.
Re: What have you done to your Golf today?
« Reply #2000 on: 10 March 2010, 17:56 »
 :laugh:
Offline AlanD
  • MK5 2.0T 16v
« Reply #2001 on: 10 March 2010, 17:59 »
You should get a 9 month ban, its only fair . . . . . :D
The 3 points shouldn't effect your insurance tooo much so count yourself luck.
People like you make me sick, so dangerous  :sick:
Offline Khare
  • The bear that khares
« Reply #2002 on: 10 March 2010, 18:03 »
Gave it a quick clean at the jetwash, installed my new boot build (pics to come at some point) and sorted tire pressures out.
Offline Dan34
  • VTEC Powerzzzz
« Reply #2003 on: 10 March 2010, 18:04 »
The 3 points should effect your insurance tooo much so count yourself luck.
lol!  :grin:
Offline leeasson
  • black 8v GTI
« Reply #2004 on: 10 March 2010, 20:37 »
fitted a new screenwash pump, the clown who last fitted one put in a renault part that only had one outlet for the back washer.
So finally, I have a clean windscreen
 :grin:
Offline Carl MK3 GTI 8V
« Reply #2005 on: 10 March 2010, 20:58 »
Todays list
Fixed the horn loose wire!
Done the tire pressures
Gutted the rear of the car didnt go to mad just seats, carpet, trim, spare wheel!!
Track day is getting ever closer!! :grin:
Offline northeast_gti-t
  • "1.8T AGU"
« Reply #2006 on: 11 March 2010, 19:12 »
ordered some front and rear discs and front and rear pads ready for saturday and then re-painting the calipers to hopefully  :smiley:
2000 Mkiv GTi 1.8T AGU
Offline MrBounce
  • Bora TDi 130 Highline - usually filthy.
« Reply #2007 on: 11 March 2010, 19:54 »
Sorted out the bulb which didn't work - was actually a loose connection. Disconnected the block, put it back together, now works...  :grin:
Keeping schtum. Mostly.
Offline mark-mk3gti
« Reply #2008 on: 11 March 2010, 20:00 »
cleaned throttle body and all ancilary pipes to it, air filter pipe and extras and cleaned out filter etc,  runs ok, then washed and polished all over, nearly finished it too, before it went dark..
Offline jmsheahan
« Reply #2009 on: 11 March 2010, 23:06 »
found some p*ick has snapped the aerial off  :angry:
