Author Topic: What have you done to your Golf today?  (Read 1111500 times)
Offline MrBounce
  • Bora TDi 130 Highline - usually filthy.
Re: What have you done too your Golf today?
« Reply #190 on: 01 May 2009, 16:33 »
Left it on the drive and walked to work (which gave me an ENORMOUS sense of wellbeing...) but will be using it tonight to go to friends' house to have CURRY mmmmmmmmm  :smiley: :tongue: :tongue: :tongue:
Keeping schtum. Mostly.
Offline the dude
« Reply #191 on: 01 May 2009, 16:49 »
put the original wheels back on, and booked her in for a well overdue service! :tongue:
Offline DANNYGCL
  • but plug thumb and jizz cookie)
« Reply #192 on: 01 May 2009, 17:23 »
Cleaned it, Sparkle Sparkle Sparkle, its nice. Still dont like it tho  :cry:
usually I am listening to my own pistons trying to make a bid for freedom through the sump
Offline dan_apps
  • too low for british roads!
« Reply #193 on: 01 May 2009, 20:28 »
today i bought a new power steering belt & ordered 2 new front discs (drilled and grooved brembos) & some mintex pads :cool:
..............fiitting will commence next weekend!
Offline JC
  • Back in the North.
« Reply #194 on: 01 May 2009, 20:43 »
but I'm not here  :lipsrsealed:
Offline jepc86
« Reply #195 on: 01 May 2009, 20:50 »
Gave it a quick wash as had a little accident in scotland on a break away and was covered in mud!!
Offline dan_apps
« Reply #196 on: 01 May 2009, 20:58 »
i can do sum things myself dial-a-canic! :rolleyes: :grin:
Offline JC
« Reply #197 on: 01 May 2009, 21:01 »
bet I get a call  :grin: :laugh:
Offline tony_ack
« Reply #198 on: 01 May 2009, 22:32 »
Had a long list and some spare time today...
First the good...
1. Cleaned idle stabilisation valve. Idles a little better now
2. Cleaned my Jetex panel filter
3. Changed the plates as the old ones were damaged. Pleased to see no rust at all under the rear plate!
Now the bad...
4. Jacked it up to change the DTM back and centre silencer for genuine VAG ones, only to find a full custom system fitted. Need a downpipe and front silencer now!
5. Tried to fit new a new heater cable. Got one clip off the old one. Cursed. Cursed some more. Got the other clip off. Cursed again. Fed the new cable through. Cursed some more... you get the picture... Took about two hours until I got it 'close enough'. Those clips are a pig.
6. While half the dash was in pieces I decided to go the whole way and try to fix my rev counter. Turns out the clocks have gone. At least I managed to break the remote central locking in the process!
1992 VW Golf MK2 GTI
1995 VW Corrado VR6
Offline jezza16v
« Reply #199 on: 02 May 2009, 21:53 »
Took the grille, front bumper and slam panel off and straightened out the n/s chassis leg using an axle stand and the self weight of the car to bend it up, did a bit of hammering to shape things up properly and fitted a new slam panel, all back together now the o/s front of the car is now the same height as the n/s and the bumper and grille looks straight at last. Gave it loads of waxoyl everywhere to preserve it. Just need to get the new s/h bonnet sprayed up now and it'll be well sorted  :smiley:
