Author Topic: fitting mk3 2.0 8v engine into my mk2  (Read 8795 times)
Offline nealey
Re: fitting mk3 2.0 8v engine into my mk2
« Reply #10 on: 06 April 2009, 19:10 »
no its a 2 litre engine
You said a couple of posts above its a 1.8 driver
I think you will be lucky to get that all swopped and running in a couple of days, its a massive job and i can see there being quite a few differences between the mk2 and mk3 stuff for example fuel system and exhausts
Offline maxp
  • J reg 8v digi gti
« Reply #11 on: 06 April 2009, 20:43 »
Think he's got the mint 1.3 golf mk2, the donor 1.8 golf mk2 and just the engine/loom/ecu etc from a 2.0 mk3 (plus a very busy looking garage!)
Offline nealey
« Reply #12 on: 06 April 2009, 21:27 »
Just reread it and i agree, a mint 1.3 mk2, a mk3 1.8 and 2.0engine and various bits
Offline euro-gti
« Reply #13 on: 09 April 2009, 09:45 »
yeah someone is reading,
anyway started the workl yestoday and as usal problems started ariving,
the mk3 engine had a hydraulic clutch on it so i had to find a full hydro clutch sytem then when i got back it looked like there was no way to mount a new clutch pedal as theres alot in the way on the bulk head,
second problem was the rear driver engine mount i would have to fabricate somthing but a mk2 gti mount fitted perfect and i have a mk2 gti gearbox now which also fits al i have to do now is find linkage,
while i could do anything yestoday i spent a good 2 hours polishing my engine bay so now its super shiney and looks sweet,
i also replace the hubs bigger discs new pads an disc put in a mk 2 fuel pump should be done tonight
