Author Topic: Went to start my MK2, petrol leaking!!!!!!!!!!!  (Read 2079 times)
Offline Lap
Re: Went to start my MK2, petrol leaking!!!!!!!!!!!
« Reply #10 on: 01 April 2009, 10:14 »
I had a petrol leak recently on my 8V digi. It turned out to be the rubber hose that feeds to the injector rail. Replaced it with one from Halfords (7.6mm), was under a tenner and included new hose clips too.
Take off that big rubber boot that runs from the airbox and you'll be able to see clearly. Mine was a Digi though. I think K-jet is different.
Also, mine was only a tiny leak but I could still smell it. If yours is dripping then surely it would absolutely stink and allow you to determine if it is petrol or power steering? Having said that, my PAS leaks too but it doesn't smell!
Offline Mr Blue
« Reply #11 on: 01 April 2009, 12:28 »
Pretty much what everyone has said.
Check the fuel lines asap if its a petrol leak. Make sure you buy the correct size fuel line. even a mm too big and it might leak again...like it did on mine. Scarey moment! full tank was empty within seconds!
Check the fuel rail for cracks while your at it. They usualy crack when you overtighten the fuel line. :angry:
Offline CHRIS_MC
  • GHETTO GHOLFER
« Reply #12 on: 01 April 2009, 13:15 »
yeah my instincts were that it was petrol, cant really get under the car to see where its emanating from.
Thanks for all the help, is there any idiot proof pictures anyone has to help me identify what to check, (im at work atm)
and dont have internetz where the car is :cry:
