Author Topic: FINALIZE MY SPENDING?  (Read 3394 times)
Offline jake
« on: 30 March 2009, 23:20 »
In three weeks im going to have around 1,000 to spend on my 1.8t, at the moment my car is 193bhp from a stage 1 remap.
Its the ARZ engine so runs off the ko3.
I want to upgrade to the ko3s turbo to get to around 240-250bhp. I have read alot of threads about this but i just want to finalize things
before i start spending.
If i buy a ko3s will it bolt straight onto my existing manifold?
Can i run it off standard injectors?
I am going to be purchasing a front mount intercooler at the same time as the turbo. Is there anything else i need apart from a remap w
when i have installed the turbo and intercooler?
thanks
jake
Offline 1688bran
Re: FINALIZE MY SPENDING?
« Reply #1 on: 30 March 2009, 23:26 »
u be lucky to get 230bhp mate ....
Offline boxxer1973
« Reply #2 on: 30 March 2009, 23:41 »
my aum on revo stage 2
Fmic milltek turbo back and cai got 220 and 256lbft torque
Offline 1688bran
« Reply #3 on: 30 March 2009, 23:49 »
  how's ur car ry ?
Offline jake
« Reply #4 on: 31 March 2009, 00:37 »
would u perhaps recommend the k04?
would the ko4 run off standard injectors?
and would i need a new manifold?
Offline 1688bran
« Reply #5 on: 31 March 2009, 00:41 »
u will need oil and water lines ,manifold,k04 turbo ,modified downpipe ,tt injectors and turbo inlet pipe ,3" maf
Offline jake
« Reply #6 on: 31 March 2009, 00:48 »
what about if i go along the route of getting the ko3s turned into a hrbrid? :huh:
would anything like that then?
Offline 1688bran
« Reply #7 on: 31 March 2009, 01:28 »
hybrid turbo ,downpipe,cat back exhaust,after market DV ,silicone TIP ,induction kit ,fmic and a custom remap  will get u around 280bhp ... jus to get the k03 hybrid turbo will cost u back near 1k ! 1k to spend on to gain performance is not that much especially to get over 240bhp mark ...
Offline sambo
« Reply #8 on: 31 March 2009, 08:36 »
Stick with the ko3s for the grand mate. I'd get the turbo, forge tip, fmic, and remap. I've just done this and got 220bhp with a small issue. Goes well though you will be suprised. If i decide i want more power i will invest in another ko3s to hybrid which can then be bolted straight on. 250 is a tough figure you either have to settle for less or spend a lot for not much more, or spend loads for BT and new manifold etc..
Sam
Sam
AXX power!  ..   Tinkering has started.... :smiley:
Offline the_stink
  • A3 140 TDI
« Reply #9 on: 31 March 2009, 14:48 »
have a look at Bav's build hes got some nice figs and has pretty much the same set up as above
http://www.golfgtiforum.co.uk/index.php?topic=104532.0
