Author Topic: My new banded steels.....  (Read 5398 times)
Offline LazyLunatic
  • MK3 20VT Project
Re: My new banded steels.....
« Reply #10 on: 31 March 2009, 23:39 »
Believe me-alot of work has gone into making these safe! But I don't think he'll be doing anymore for along time!!!!
was it a battle?? :laugh:
should look phat :cool:
i will keep a look out in a few weeks or so then at barden when i drive past, might see ya :)
Offline dan7
  • 85 T25 camper, 90 Mk2 16v, 90 Caddy
« Reply #11 on: 01 April 2009, 06:10 »
Yeah, they were a bit of a pig!!!!! Won't be on the car for 2-3 weeks, as they need finishing, painting and rubber!!!
Offline gjroe78
« Reply #12 on: 01 April 2009, 08:51 »
Did'nt think wheels were aloud to stick out that far  :huh:
kells
« Reply #13 on: 01 April 2009, 09:31 »
+1
« Reply #14 on: 01 April 2009, 09:37 »
They are not, but I believe as long as the tyre is covered then you will be ok, so with stretched tyres you should get away with it.
Offline gjroe78
« Reply #15 on: 01 April 2009, 10:01 »
They look like they may stick out even with stretched tyres on tbh  :undecided:
Offline Chris-White
  • Manufactured in Germany. Ruined in Britain.
« Reply #16 on: 01 April 2009, 10:35 »
they look legal and safe  :huh:
+1 (I'm going to agree to with sharpie  :shocked:) - they don't look legal.
seeing as banded steelies have been used in motorsport for many, many years, im sure they will be fine pootling round on a golf!
Camber them then, or it may be time for a bit of an arch pull  :cool:
Offline dan7
« Reply #17 on: 01 April 2009, 19:59 »
How do I put like 2deg neg camber on the rear of my mk2???????  :huh:
Offline LazyLunatic
  • MK3 20VT Project
« Reply #18 on: 01 April 2009, 20:11 »
camber shims?
i'll keep an eye out in a few weeks then :cool:
Offline ben harcombe
« Reply #19 on: 02 April 2009, 17:41 »
your going to have some major problems fitting tyres to those mate the recess in the middle dont look like it would allow you mite get away with it when fitting the the outer part of the tyre onto the rim you will have to squash both beads into that recess its guna be tight if you look at most wide rims they have a shallow bead at the back which is usually very wide
