Author Topic: 1.8t or 2.8vr6???  (Read 4589 times)
Offline mo_utd
Re: 1.8t or 2.8vr6???
« Reply #10 on: 23 March 2009, 15:34 »
really appreciate the comments, thank you people. so do i change the gearbox or will my std gearbox handle it??
Offline Benrevs
« Reply #11 on: 23 March 2009, 15:52 »
Vr6 is heavier with 65% of the weight at the front, move the battery to the boot will improve things aswell as will some well-placed strut braces.  The conversion is easier aswell, especially if your car is '90 spec.  Cant beat the noise!  I would change the box, you want the final drive at 3.03 rather than the 3.06 that is standard on a 2.8 golf vr6. Ben
Offline vaughn
  • now team wagon, and team grumpy trainee
« Reply #12 on: 23 March 2009, 16:31 »
both old school, this is what you want in there  :wink:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWAX:IT&item=200322065734
300 ponies with re-map and exhaust :grin:
57 plate black 5dr ed30, 1969 bay window devon camper. thats all for now folks, hopefully picking up a wagon tomoz
Offline fazzybear
« Reply #13 on: 23 March 2009, 19:35 »
Ive had three 20v now and no vr6, love the spooling noise of a turbo
got mine running at 340bhp but seen turbo'd vr's making this aswell
personally next golf will try and go vrt route  :evil:
Offline Benrevs
« Reply #14 on: 23 March 2009, 19:45 »
Charged vr's sound immense.  Im thinking of a supercharger for my next big thing.  Headgasket spacer and away you go, They are strong engines and can take a fair bit of power without any major work.
Offline Alpine mike
  • Grunt lover
Offline mo_utd
« Reply #16 on: 24 March 2009, 03:31 »
I think I'm gonna go with the vr6. Just seen some clips on YouTube and the roar is mental! Do I need to change my radiator? I should definately put g60 brakes. Anything else I should change?
Offline fazzybear
« Reply #17 on: 24 March 2009, 11:05 »
What you need is mk2vr6.com
thank me later  :wink:
Offline gstar-dubworld
  • Here comes the piano man - his a peaceful man..
« Reply #18 on: 24 March 2009, 14:20 »
With the VR conversion you will need the VR box as well as the running gear (Hubs, carriers, shafts, cable shifter etc.), with the 1.8T you can retain all of your running gear but you will need to plum in an intercooler with all the associated pipe work, both require higher pressure fuel pump, ECU's, some form of mapping and exhaust fabrication.
VR is heavy and it sits too far farward in the bay if your after outright balance on handling, power to weight ratio on the wrong side, 1.8T sits pretty neatly just as the standard motor, lighter better scope on handling.
So ultimately the choice is your on your what your after from the conversion, I wouldn't go into the fuel debate as both can be thirsty as each other depending on the state of tune/power, also very dependant on the budget, clips on youtube and the practical of the actual conversion are two very different things, so consider carefully and then select.
PS. R32 conversions sits even further forward in the bay.. :evil:
Offline Benrevs
« Reply #19 on: 24 March 2009, 15:13 »
You can retain the original shafts, hubs and wishbones.. just need to change the k-frame. Can keep your 4-stud aswell. :wink:
