Author Topic: Exhaust for Mk1 Cab  (Read 5569 times)
Offline Madone_si
  • Seattle WA, USA and Middlesex, UK
Exhaust for Mk1 Cab
« on: 19 July 2004, 14:33 »
Need help....!! I'm looking to replace my standard Mk1 Cab exhaust with a stainless system, but not sure what to go for.
Any help would be great...
Old Skool Mk1 Golf Gli (82), Mk1 US Cab 85 and 83
SOLD - BLACK SOY 92
Offline gibby
Re:Exhaust for Mk1 Cab
« Reply #1 on: 19 July 2004, 14:46 »
I started a thread a while ago asking how to get a bit more power out of my car and the exhausts that I got recommended were a Powerflow or a mongoose system. The powerflow are made to measure and will cost but Adam will be a good person to answer this one for you.   :)
......now officially dubless.
Offline Madone_si
« Reply #2 on: 19 July 2004, 15:08 »
ok thanks, I'll wait until Adam replies.... :)
SOLD - BLACK SOY 92
Offline AdamB
  • The Perfect Storm
« Reply #3 on: 19 July 2004, 15:28 »
Hi,
I started off with a mongoose back box and centre pipe, however the backbox will need a custom bracket made for it, as the cab has a slightly different mounting system to the tintop. This was fine, and provided a nice exhaust note and a difference in performance was noticed. However because of the size of the central silencer, it did cause me some problems when I lowered the car again, so I had the centre silencer removed and a powerflow pipe put in its place. I also had the standard mongoose tailpipe replaced with a carbon fibre wrapped powerflow tail pipe. This fills the hole in the Clipper bumper nicely.
The car sounds great and goes will with it, and has a noise of 109db (meauserued) so it's not excessively loud, but will still turn heads.
Mongoose come with a lifetime garauntee, but I have probably invalidated it with the mods, but this is a good sign of their confidence in their product.
However, I would probably not go down this route if I had to do it again, I would just have powerflow custom make me an entire system.
I don't own this anymore - I just can't be arsed to change the picture
Offline Madone_si
« Reply #4 on: 19 July 2004, 15:38 »
for anyone interested here is powerflows URL - http://www.powerflow.uk.com
Thanks Adam.  :)
I owe you a few drinks for all this advice...
SOLD - BLACK SOY 92
Offline stubbsy
« Reply #5 on: 19 July 2004, 22:44 »
i had a powerflow full stainless on myn, im realy pleased with it as it only took them 3hrs to make and fit, you get a lifetime garuantee with them and you can also have it as loud/quiet as you like. all for ?250 fitted. you can also choose your own tailpipe design, i just went for a 3" outwardly roled tip
ive heard that supersprint ones are supposed to be good though.
Offline gibby
« Reply #6 on: 20 July 2004, 08:17 »
?250 made up and fitted, I thought they would be more than that, that's a damn good price.  :)
Offline AdamB
  • The Perfect Storm
« Reply #7 on: 20 July 2004, 08:27 »
?250 is a bargain when I think my mongoose system alone was more. Adding in the custom work I had done by powerflow pushes it up near the ?400 mark. - it is one of a kind I suppose though.
Offline richandhazel
« Reply #8 on: 22 July 2004, 13:14 »
I can't recommend powerflow enough, they are superb. Had a complete, cat removed, system fitted to my Audi for less than the price of two rear boxes from Audi!
I plan to change my exhaust manifold on my cab from a 4 into 1 to a 4 into 2 and then it'll be off to powerlow to have the rest of the system custom made.......something like yours I expect 'stubbsy' ;) ?250 is the rough quote I was given too..........excellent value :)
Offline gibby
« Reply #9 on: 22 July 2004, 13:21 »
Rich, where are you getting your 4 into 2 manifold from then and how much ?  :) Will that give the cab more umph then ? Wouldn't mind doing something like that on mine but wondered what else needs to be done to maximise the 4 into 2.  ???
