Author Topic: Misfire diagnosis..  (Read 1392 times)
Offline MrTurner
  • Facelift leon cupra
Misfire diagnosis..
« on: 21 March 2009, 11:06 »
Right who can help..
I'm sure this fault has afflicted many people, and I'm almost certain that searching for it will give results...  But bear with me  :wink:  I worked a 16 hour and 12 hour day last week, and am still working 6 days a week.  I'm at work as I type  :embarassed:  So - I'm calling on you pro's as I've not got the time to faff about!
I've got a slight misfire, so could either do with a defo reason of what it is, or for someone local to vagcom me in the next couple of days.  I'm at work Mon-Wed, then having surgery Thur before hitting the rolling road Sat.  I was going to leave the car as it is and RR it knowing the power is down, but I want to fix it first  :smiley:
OK - I'm sure I've had this fault before, and I think it was the MAF (after I'd changed the lambda) on my 306gti.
When driving consistently no rash acceleration, just around town, it feels fine and smooth.  then, really open it up and it hesitates and holds back slightly, it then clears it's throat, but still feels a bit down on power.  No lights on the dash, no noticable mpg loss (poss 1-2 down, not a lot).  It starts and drives fine, was a little hesitant to start the other day when it was pretty cold, but still started first time.
I'm guessing MAF or maybe even a coil pack, but what do you guys think?
Dai - I take it the MAF is in use on yours, and different between 2.0&1.8T  :grin:
Offline dai-cymru
  • 1989 MK2 16V
Re: Misfire diagnosis..
« Reply #1 on: 21 March 2009, 11:10 »
Yes mate different i had to buy a new one for £78 (and didnt fix my running probs) starting to hate the 1.8T engine at the moment,
With Ref to your probs the coil pack loom are known for chaffing through, could be the start of that chaffing through :undecided:
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
« Reply #2 on: 21 March 2009, 19:13 »
I've got a fault code reader (only an eBay special, but does the job ;)) if you can get upto Solihull J5 M42 (or even 6 because that's closer, & I'm nice! :D)??
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
« Reply #3 on: 21 March 2009, 19:15 »
p.s.  You changed the plugs recently/have they been changed in the last 20k?
Offline MrTurner
« Reply #4 on: 21 March 2009, 19:26 »
No time to get to Solihull  :grin: barely enough time to get to the stealers!
Sparkers were changed at 167k, November last year.
