Author Topic: Angel Eyes on a mk5? What you reckon?  (Read 9267 times)
Offline Jimp
Re: Angel Eyes on a mk5? What you reckon?
« Reply #10 on: 16 March 2009, 18:32 »
I have the same set ready to go into mine  :smiley: Just need to figure out how to wire the DRL strip to actually work as DRLs instead of glorified sidelights. Hurdy and Komenda have them too!
Not low enough mk5
Not on the road enough mk3
Offline Komenda
« Reply #11 on: 16 March 2009, 19:27 »
When you fit them solder all the LED cables together, then isolate the side light cable from the light terminal, strip a little section of wire cut it and fit it all together with a crimp connector, job done in 10 mins a side tops.
et voila LED DRL's
Offline Jimp
« Reply #12 on: 16 March 2009, 19:50 »
et voila LED DRL's
Just wondering would this only turn them on when the sidelights come on or would they be on whenever the engine is running?
Not low enough mk5
Offline Komenda
« Reply #13 on: 16 March 2009, 19:57 »
Only when you turn the sidelights on
Offline Jimp
« Reply #14 on: 16 March 2009, 20:04 »
Is that how they are supposed to work? Like on Audis and such? I thought the DRLs were meant to be on whenever the engine was running.
Not low enough mk5
Offline Komenda
« Reply #15 on: 16 March 2009, 20:08 »
They are but it's a bit more work messing with the switch, and we didn't have the required skills.
Offline Jimp
« Reply #16 on: 16 March 2009, 20:11 »
Fair enough. Thanks for the info mate  :smiley:
Not low enough mk5
Offline Komenda
« Reply #17 on: 16 March 2009, 20:18 »
No probs, have fun
Offline Hurdy
« Reply #18 on: 16 March 2009, 21:03 »
Upgrade the bulbs for nightbreakers :cool:
Seat Leon Cupra Black 290 DSG
Offline sambonumber5
« Reply #19 on: 17 March 2009, 07:06 »
I haven't had a problem with light so far-in fact i would say there's probably more light on the road now than with the standard lights.
Looking for some rear clusters to match now - ideas?
