Author Topic: has anyone fitted one of these?  (Read 6424 times)
Offline dan_b998
Re: has anyone fitted one of these?
« Reply #10 on: 17 March 2009, 23:07 »
the hood i was lookin at was fitted to the car
in the picture i mean
i'm kinda guessin i won't get a new window but do u get the inner skin aswell and all the waddin inbetween the 2 layers
also do u get a new window seal
i'm goin to b fittin a new roof in the furture an greeasin the mech as its a bit on the stiff side
and my roof has been ripped i cna get a mohair hoodfor 215 with 15 postage off ebay
it doesn't say weather it comes with the other bits i mentioned cnas anyone answer that for me who has bought a hood b4
« Reply #11 on: 18 March 2009, 08:52 »
han do you mean the insulationy stuff inside? if so the covering over it was a bit screwed so we had to re-sew some fabric over the top, but apart from that no packing was required :)
no other seals are included, just the hood material itself, we got some glue to stick it plus black sealant for the rear screen, and some rivets.
Dinky
« Reply #12 on: 18 March 2009, 22:15 »
I think you'll find I'm called dinx.... bit of a difference...
Yes, the insulation/packing, this I am assuming is between the liner and the actual hood. Just I know sometimes when removing/changin cables can result in a different shape, shall we say, of the hood
cheers
Offline dan_b998
« Reply #13 on: 20 March 2009, 00:19 »
so if its just the outer skin i'm gettin what can i use as the insulation stuff an is there anywhere i could get the iner skin fromaswell and how hard is it to fit
« Reply #14 on: 20 March 2009, 08:19 »
sorry about that  :embarassed:
Offline Stone0311
« Reply #15 on: 07 April 2009, 11:56 »
Have fitted two of the hoods from this ebay supplier - couldnt find any faults with either of them, strange as it says they are seconds.
Bit of a sod to fit - this guide helped though:
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=12313&start=0
You can get the rubberised horse hair that goes in between the outer and liner from here
http://www.woolies-trim.co.uk/p-1532-rubberised-horsehair.aspx  - 1 sheet should be enough
You need to fabricate a material liner though if yours is dead (see pics) make yours a bit wider than mine though to cover the hinges on the edge, i used heavy white cotton with water proof ripstop edges):
Before
After
