Author Topic: hydraulic fluid....  (Read 2975 times)
Offline Khare
  • The bear that khares
Re: hydraulic fluid....
« Reply #10 on: 12 March 2009, 17:40 »
 :grin:
Offline DarnPB
  • Formerly Darnpistonbroke
« Reply #11 on: 12 March 2009, 22:31 »
i drank a fair bit of parrafin once. Wasnt pleasant.
dont ask  :lipsrsealed:
Vets used to force feed cows parafin to clear stomach blockages.
Offline Chris-White
  • Manufactured in Germany. Ruined in Britain.
« Reply #12 on: 12 March 2009, 23:25 »
it certainly did that  :sick:
Offline Ben Lessani
« Reply #13 on: 13 March 2009, 08:40 »
Brake fluid every 2 years? Jeez, I ain't done mine in about 5 ... but given the rate at which fluids escape my car, they're probably air brakes now, along with my air tappets and air steering.
« Reply #14 on: 13 March 2009, 09:20 »
Brake fluid needs changing every 2yrs due to the moisture that it absorbs.
Offline Teutonic_Tamer
« Reply #15 on: 13 March 2009, 10:37 »
But if you had changed it every two years, you probably wouldn't have ended up with other fooked brake components.  As wayned correctly points out, brake fluid absorbs water - and if this water is allowed to remain in the system, it can cause the insides of your wheel cylinders, master cylinders and calipers to corrode from the inside.  A new master cylinder is much more costly to repair/replace compared to a litre of brake fluid every 2 years.  :wink:
I feel like a homo
Offline VRDan
  • VR6ing all the way home
« Reply #16 on: 16 March 2009, 20:10 »
 ^^ good point. Brake fluid is Hydroscopic so absorbes moisture, this makes the fluid in your lines compressable and can cause a bit of a spongy pedal.  :smiley:
My VRSex!!
Offline theshrew
« Reply #17 on: 18 March 2009, 16:08 »
Correct
Offline Len
« Reply #18 on: 18 March 2009, 16:33 »
Just as a matter of interest how does moisture get into a sealed system?
www.sas.org.uk
www.the-ace.org.uk
