Author Topic: Bolts as stubborn as me - I'm going to cry!  (Read 2950 times)
Offline Ben Lessani
Re: Bolts as stubborn as me - I'm going to cry!
« Reply #10 on: 12 March 2009, 20:07 »
Sod the WD40, sod the giant breaker bears and so the heat.
Just borrow an impact gun or go to a garage, you can buzz em off in about 5 seconds. Get the right tools and you won't have to spend a tonne of money buying new parts after trashing them with the wrong tools.
VW BUSH
« Reply #11 on: 12 March 2009, 21:23 »
And when you put the new ones in, use copper slip and dont over tighten :wink:
Offline Ben Lessani
« Reply #12 on: 12 March 2009, 21:59 »
Copper slip on crank pulley bolts?
Offline Mikester
  • Civic Type R
« Reply #13 on: 12 March 2009, 22:01 »
And a blowtorch for good measure ;)
« Reply #14 on: 12 March 2009, 23:21 »
Should be loctited just think what would happen if they fell out.
Offline Ben Lessani
« Reply #15 on: 13 March 2009, 08:11 »
No threadlock or copper slip!
Torque em up to about 50Nm and you'll be good to go.
Offline slicksps
  • Web Design and now DIY mechanic for mkIII CL
« Reply #16 on: 13 March 2009, 16:20 »
Thanks a billion for your ... mixed responses :)
I helped my neighbour last week with a jump start so begged her to get her mechanic boyfriend to do it and he did.
Timing belt changed and all good, need to get a bottom cover at some point because it looks like it was borked by the last people who changed it. (Removed completely for now as it's safer than leaving it in; warnings above heeded)
Engine runs fine, but now I'm paranoid, how can I tell the timing belt is on exactly the right teeth? There seems to be a bit more noise than before but performance doesn't seem to have degraded. I'll know properly tonight on a drive to Wales.
Offline davero
« Reply #17 on: 13 March 2009, 16:26 »
Glad you gotted sorted mate. Opinions are always going to vary with this sort of thing
Offline harlemex
« Reply #18 on: 13 March 2009, 16:50 »
What sort of noise is it?
If it whines then the belt might be a touch too tight and need slackening.
Offline slicksps
« Reply #19 on: 13 March 2009, 17:24 »
It sounds a little... sportier...
Don't get me wrong, I do like it, but it sounded more conservative before.
I did also change the spark plugs just because I could and there was no record of when it was last done...
The more I do to this car the more I realise how little I really know... following steps in Haynes isn't the same as 'knowing stuff' - Today I fitted alloys, drove back round to my house from the side street and one tyre was making a very odd noise... I checked online, checked the book and put it down to needing breaking in... it was still bugging me so I went back out and it turns out I didn't actually tighten the bolts and I'm lucky to still have that wheel and attachments. t**t!
Mechanics out, I'm sticking to web design... I do understand computers.
