Author Topic: Stretching tyres/Alloy question.  (Read 2700 times)
Offline Len
Re: Stretching tyres/Alloy question.
« Reply #10 on: 11 March 2009, 13:23 »
I used to run 215/40/17 with no problems!
So its definitely the larger profile thats doing it!
www.sas.org.uk
www.the-ace.org.uk
Offline Dec
« Reply #11 on: 11 March 2009, 13:25 »
one of my wheels used to catch more than the other, i just got the arches cut back a bit :evil:
Offline spunkymonkey
  • Tepidly moist! That's what that is!
« Reply #12 on: 11 March 2009, 15:49 »
mine dont catch but the pass rear wheel sit slightly further out than the drivers side. think i may have a thin spacer in my garage somewhere.
Offline MowatGTI
« Reply #13 on: 11 March 2009, 16:25 »
Cheers.
Not sure if I should put my good tyres on now, or leave the others untill it wears the sidewall through!  :evil:
It is scrubbing so much that I would have though it might have scrubbed a bit on my other tyres, but in the two years I ran the car it never scrubbed once.  Can't believe the 10mm makes such a difference.
Cheers again.
Offline Len
« Reply #14 on: 11 March 2009, 16:43 »
If its scrubbing the sidewall, probably against the strut, then that can be dangerouse as the sidewall of a tyre is the most delicate!
Could be heading for a high speed blow out!
www.sas.org.uk
www.the-ace.org.uk
Offline MowatGTI
« Reply #15 on: 11 March 2009, 16:47 »
Sweeeeeeeeeeeeeet! :evil:
Its on the outer side wall.  Scrubbing on the metal (rust) on the most forward part of the o/s/r arch.
I'll keep an eye on it.  Only scrubs when I hit a speed bump.
« Reply #16 on: 11 March 2009, 16:49 »
If it is catching the metal arch, I would try and get it sorted asap as you could damage the tyre.
kells
« Reply #17 on: 11 March 2009, 17:25 »
if i was to run a 17 inch rim id go 195/40/17
Offline Dec
« Reply #18 on: 12 March 2009, 09:12 »
My mate runs 185/35/17  :cool: special order from Japan and took 6 months to come!
Rubber band tyres:
« Reply #19 on: 12 March 2009, 09:18 »
Rubber band tyres:
The ride must be shocking.
