Author Topic: mk1 golf cabby rear disc conversion and power steering conversion???  (Read 7443 times)
yeah for some reason they wont work for me, they came off a scirocco that was on the road so I'm a bit confuzzled.  Unfortunatly car has now been scrapped so I cant check what was done!
edit: yeah and corrado stub axles will work, pretty sure MK3 ones will too
Offline dan_b998
just a quik power roof Q
if i got the rams an pump all the bits i need can' i make them fir my rof frame cos there is the whole lot with the wiring on ebay at the mo quite cheap
also do the cabriolets with power roofs stil hav the side handles at the front to hold the roof dwn
the strut attachments in the c pillars are different, but you might be able to make it work i guess?  there are still lock handles at the front.  its actually quicker to fold the hood manually  :grin:
edit: dont forget you need al the brackets to weld into the boot
Offline dan_b998
well i mite think about leavin the power roof then if i can d it quickerr by hand lol
but i will need to change my roof ass someone cut a hole in it
it this easy
roughly how long would it take
