Author Topic: need new CV joints, as cheap as possible!  (Read 919 times)
Offline Khare
  • The bear that khares
« on: 09 March 2009, 16:37 »
right, im suspecting my outer passenger CV joint is knackered and im looking to replace. GSF is £58 and ECP is £51 for the CV joint kit. Is £51 the cheapest I will find or is tehre any site that does them cheaper? i need to have them at home on friday!
Offline boneybradley
  • Back in a Mk3...
Re: need new CV joints, as cheap as possible!
« Reply #1 on: 09 March 2009, 18:10 »
are you sure its knackered?? I was told my cv was the creak issue on mine and it turned out to be the hub!
oh and £51 for the cv is very expensive!! I can get them for £30-35 (exchange) with the boot included or the whole driveshaft for £115
Offline Khare
« Reply #2 on: 09 March 2009, 18:15 »
dude. fixed  :smiley: cheers for help though!  :smiley: :smiley: :smiley:
  • Back in a Mk3...
« Reply #3 on: 09 March 2009, 18:19 »
was it the cv?
Offline Khare
« Reply #4 on: 09 March 2009, 18:23 »
was it the cv?
i had a very wierd grinding nosie fm n/s front and me and diamond hell suspected CV joint, as the boot is split and most of the grease is around the wheel so we thought joint might have run dry. Just been outside, jacked car up removed wheel and noticed a very distinctive groove on the brake disc, had a look why it was tehre and the metal shield behind the disc was touching it :shocked: :shocked: :shocked:
took it for a spin and was so relieved to hear the noise wasnt tehre. :cool:
