Author Topic: french tailgates and number plate lighting.  (Read 3928 times)
jamie16v
Re: french tailgates and number plate lighting.
« Reply #10 on: 08 March 2009, 10:17 »
cheers wayne
Offline CHRIS_MC
  • GHETTO GHOLFER
« Reply #11 on: 08 March 2009, 10:34 »
my mk3 failed its MOT on the brake pipes AND the rear numberplate lights
« Reply #12 on: 08 March 2009, 11:22 »
jamie16v
« Reply #13 on: 08 March 2009, 11:56 »
will do when i get the batteries charged on the camera mate, not got a lot of time on my hands today.
cheers, jamie.
Josho
« Reply #14 on: 08 March 2009, 14:51 »
French tailgates are sh!t.
You are just post whoring, and how did this help! STFU sometimes josho. Do you even know what frenched is???
Humour.
jamie16v
Re: french tailgates and number plate lighting. pic added
« Reply #15 on: 09 March 2009, 18:34 »
as requested, excuse the rush spray job, used whatever paint i had left in rattle cans.
kells
« Reply #16 on: 09 March 2009, 18:45 »
the correct way to smooth it is to extend it, basically by welding a metal plate over where the standard lights are, hence you dont need to change the standard ones if that makes sense
jamie16v
« Reply #17 on: 09 March 2009, 19:14 »
i did weld a plate in mate, but the standard lights wouldnt have fitted under the plate. these are quite slimmer.. once i cut a hole for them they will sink in nicely, i left gaps in the steel for them and then just reinforced it with fibreglass from inside the boot before i fillered.
as you can see, its not finished yet, if you look at the two top corners they are a different shape.. it was getting dark and i knew i had to use the car the next day so a lick of paint just to stop it rusting was needed.
Offline Ashley
« Reply #18 on: 09 March 2009, 19:32 »
couldnt you just get a couple of ultra bright LEDs and tucket them up into the holes where you've put the temporary ones? could even put a couple together on each side and try conceal them as much as possible
had a bugger of an MOT a couple of years ago trying to get 2 rusted, rounded screws out to change my number plate lates, so they're definitely a requirement  :drool:
« Reply #19 on: 09 March 2009, 19:40 »
I have seen a lot where they bring the plate down over the lights, I am sure they keep the standard lamps as well.
